3.1L V6 dies when given very little throttle, can't find idle when driving
So this has me scratching my head, the car revs up just fine, only issue is idle sounds rough and spark is weak. Constant check engine light as well, comes up as code 33. My mechanic said the distributor might be bad, is that a possibility? Just looking for second opinions since it's such an odd issue
Car: 1991 Firebird V6
Engine: LHO V6 N/A
Re: 3.1L V6 dies when given very little throttle, can't find idle when driving
https://www.freeautomechanic.com/gm-...af-sensor.html
All things are possible, correctly diagnosing the issue is when a real mechanic comes in and not just a guy that can guess and change parts.
Also, a somewhat quick check without any tools that will tell you if the issue is your MAP would be to unplug its electrical connector and then attempt to run the car. The ECM should sub a default value for manifold vacuum if functioning properly. If running improves that lets you know that either the sensor itself or the associated wiring is going to be the cause of your problem. Again a proper diagnosis is usually the only way to find the root of your problem.
Last edited by Redcon1_Regabu; Jun 17, 2022 at 03:17 PM. Reason: Additional information
