Adjustable Timing Tab Off
Old May 22, 2024 | 07:51 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
First, this engine only has 30,000 miles on it. I decided that while I had the engine out to paint the bay, I would replace gaskets of the timing cover and the water pump as well as the front oil seal (had a little leak), I thought it best to check the timing tab since it was set way off to the side. I lined up the timing marks on the crank and camshaft right at TDC. I slid the timing cover on and the damper (if I remember correctly I bought a new damper at that 30,000 mile rebuild). When I checked, the damper timing mark was about 4 degrees past the TDC "0" mark on the tab. Guessing that I set it to 10 degrees at the rebuild I think I have been running at 6 degrees all this time. It has been running pretty good but I did notice less power after the rebuild and lower than previous gas mileage. I reset the tab to TDC for the damper mark to put it back together. Will set it to 10 degrees once I put the engine back in the car.
Old May 22, 2024 | 08:06 PM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Re: Adjustable Timing Tab Off
Oops... I think I got that backwards. With the damper at TDC 4 degrees past the "0" mark on the tab, then setting timing to 10 degrees on the mark would mean I was running 14 degrees all this time....
jraider66
Jul 9, 2013 10:36 AM
stevek
May 23, 2010 02:06 PM
jeb455
Jan 30, 2007 08:29 AM
icanoutfishyou
May 19, 2004 07:30 PM
BOTTLEDZ28
Apr 15, 2002 11:13 PM
