Starter Replacement?
Old Jan 4, 2025 | 11:59 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
What is the best starter to put on my engine? I am tired of starter failures....
Old Jan 4, 2025 | 08:21 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Starter Replacement?
I have had good luck with NEW starters from Autozone and OReillys. NOT to be confused with the "reman" garbage.
Old Jan 4, 2025 | 09:04 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
my lt1 starter from autozone has been bulletproof for 7-8 years now
Old Jan 4, 2025 | 10:12 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Your car is also a V8...
Old Jan 4, 2025 | 10:14 PM
TylerSteez's Avatar
Engine: 383 stroker
that’s my bad
Old Jan 11, 2025 | 12:27 PM
KITT87's Avatar
Car: ‘87 Base Firebird
Engine: 2.8 V6
Old thread but I bit the bullet and bought a new (not reman) ACDelco starter on rockauto 6 months ago. Been holding up great so far.
Old Jan 11, 2025 | 02:40 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
If you're having frequent starter failures, that's not a starter problem, you probably have poor battery cables/bad battery or a mechanical issue with the flexplate/flywheel, depending on exactly what is failing.
f0rmula350
Apr 10, 2003 02:08 PM
