Hey would this work on a 2.8
Old Feb 12, 2002 | 10:32 PM
Bluerocket's Avatar
I was woundering if this kit would work on the 2.8 because it works on the fiero 2.8
http://webhome.idirect.com/~rsm1/supercharger.doc
Old Feb 13, 2002 | 02:19 AM
BitchinRS's Avatar
You gotta remember, the f-body engines are monted north and south. The Fiero engines are monted east and west. This will cause a problem with the hook up of the pipes and other stuff they supply. Allthough anything can be done with the right amount of money and work.
Old Feb 13, 2002 | 06:44 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
where would you mount the power steering pump? looking @ the pic, on my bird, the power steering pump sits where the charger bracket is.
Old Feb 13, 2002 | 07:13 AM
Brian K's Avatar
usually one would just buy the super and custom make the brackets and tubbing.. It would be cheaper...
Old Feb 13, 2002 | 10:33 AM
KED85's Avatar
All the guy did was take a centrifical charger, get a bracket made, included nuts/bolts for a Fireo.
It's simple.
You can easily do this on the F bodies.
Old Feb 13, 2002 | 05:12 PM
Camaro_hunter_d's Avatar
And do not forget who would not happily give up there P/S for a 'Charger? I would. IF the price was right. How much is that thing? But hell then again he is using half of a turbo, so then you could make it yourself cheaper.
Old Feb 13, 2002 | 11:40 PM
KED85's Avatar
All it is is a Paxton small sized supercharger.
www.paxtonsuperchargers.com
The_Phoenix
Feb 4, 2016 07:10 AM
hectre13
Aug 26, 2015 08:17 AM
matthew911
Aug 12, 2015 09:38 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
squiggy2
Aug 9, 2015 09:30 PM
