View Poll Results: The turbo compatable headers
Yes I have time do the series 1 then the series 2
78.95%
I can't wait just do the series 2 Turbo style
21.05%
Multiple Choice Poll. Voters: 19. You may not vote on this poll
The Headers... consider it a consumer poll
Old Mar 2, 2002 | 03:49 PM
  #51
Camaro_hunter_d's Avatar
I called a place yesterday on the block for me to pick up today and the guy was a no show. So I have to wait till monday(Which I have class late 6pm) so I can get on it then. But just remember after I get that block to mold on and with spring break right around the corner I should be able to get several sets done ina very short period of time. I also finaly got a pointer on my degree wheel so I can measure down to 1* changes.
Old Mar 2, 2002 | 04:17 PM
  #52
WaynesRS's Avatar
Good gosh man , HURRY UP !! NO , im JUST KIDDING MAN ...heh ....I will be purchasing a set from you , but not real soon .As you can see in my sig Hunter , I just burned up 3rd and 4th gear in my tranny .Ive been without my car sence tues , its in the shop now .Costing me $1000 so Im kinda saving my cash now ......Once you get the headers going , and maybe this summer when your off from school , what would be cool is to make a custom y-pipe . We are ganna need em ya know , so you might as well make some cash with that to ....Glad everything is finally coming together for ya man ! Goodluck !
Old Mar 2, 2002 | 05:31 PM
  #53
Yeah I am getting really frustrated with all the snags too. I would have loved tobeen able to get htese things going oh like a month ago, then I could have my car paid off and been saving for the turbo build up.
but as someone asked before I have quite a bit of money tied up in this so far, though The bender I will use to make more then just headers(Like a custom roll bar with the low side rails) Better to have spent 500 on that bender and be able to make not only the headers, but with an additional die to make just about anything else too like a Strut Tower Brace, sub frame connectors, Lower control arms.. ect ect...
Old Mar 2, 2002 | 08:23 PM
  #54
Ovrclck350's Avatar
Hunter...think I'm gonna hold out on the turbo headers.
Thinkin of a turbo 3.4
Old Mar 2, 2002 | 09:52 PM
  #55
AH the beauty is that the type I am going to make now once I get the block to design around WILL be turbo compatable. You just ned to wait for me to get the rest of the system put togeather.
Turbo compatable does not mean ONLY turbo. You can still have a shop make the Y pipe go back to your cat. BUT if you want the turbo set up sorry your just gonna haft to wait a while...
Old Mar 2, 2002 | 11:12 PM
  #56
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I notusing my block for anything, meet ya in Indy for the drop off
Old Mar 2, 2002 | 11:18 PM
  #57
Trust me if it was not like 7 hours away I'd bite...
even better checked yahoo maps and its 5 hours each way... wa hoo!
Old Mar 3, 2002 | 03:38 AM
  #58
maverick544's Avatar
You said that we should gain around 10-20hp. Is that with stock catback and CC or what. ALso how much would a y-pipe cost from most muffler shops. And if you got time can you make a y-pipe for they headers, it will make life alot easier. ALso are we going to have to worry about ground clearance with these headers on ours V6s
Old Mar 3, 2002 | 09:11 AM
  #59
DeadHero8's Avatar
so hunter if i wanted to down the road i could get a turbo and slap it on here, with these headers
Old Mar 3, 2002 | 01:35 PM
  #60
yes and no. You need the Y pipe made for the turbo connection. I will be doing this really soon. I WANT A TURBO MOTOR. But I will get the system close to done before I sent it out for sale. I want to get the BIN/ECM Prom correctly programed with the needed mods to handle the aded MAP pressure(PSI) and have the fuel and spark tables modified so your pistons will not burn up and leave a nice puddle of aluminum in the crank case. When I get this system installed on my car I will test and run the system for as long as I can to see what the limitations are. I will start with a modest 5PSI and tune that. Then 7PSI and tune that ect ect until I have a program that will run up to 12 PSI UNDER STABLE CONDIDTIONS.
Then after I get the mottor rebuilt and the 4.3 ready to swap in I will reinstall the 3.1 and boost untill something breaks and record what is needed for each step and the mods needed to support it. To put it this way i want to get about 300 HP outta this 3.1 turbo. Thats realistic and quite a surprise to a Z racing you.
As the HP/Trq gain, I am going by what has been posted as that the hedmans have gained 10-15 maybe more ON THEIR OWN. Now MINE ARE DIFFERENT FROM THE HEDMANS. I expect to get similair results however. Plus mine have the option of the turbo.. Hmmm... Now you add the Cat bach high flow cat ect ect, you get more power. So in all you could get 25 HP from the headers, Y pipe, high flow cat and cat back system.
Old Mar 5, 2002 | 12:48 PM
  #61
Keoki_Firebird89's Avatar
I Want the turbo style!
i have left over money in my pocket
and its either going to ignition stuff or one more engine part before the 3.4 comes in
i have about 150 bucks left and still more comming
if not those 150 are gonna start buying the turbo stuff to have some stuff in advance
so camaro hunter i also need a list of stuff to prepare my engine for boost
and you got a customer in me for the turbo stlye
George
i gotta make a signature... but don't know how
Old Mar 5, 2002 | 04:46 PM
  #62
Ok. I have the block now sitting on a stand in my garage. This week I plan on having the molds done. and have pics of them on the block on the stand. I also got the factory manifold so I know the location and sice of the EGR stuff.
Mods to have the turbo.
1. Rebuild the engine.
2. Lower the compression to AT LEAST 8:1
3. Performance bearings all around.
4. Debur the oil passages in the block to aid oil flow.
5. The strongest pistons you can get.
6. Stock CAM WILL WORK, Turbos like MILD CAMS HOWEVER. More lift the better too.
7. Cooling system. Stock will work fine. Just make sure you have 100 percent flow and the system is clean.
8. Oiling system. I would recomend a low pressure HIGH VOLUME pump. Volume for keeping the oil cool.
9. Speaking of keeping oil cool. GET AN OIL COOLER. Install it before the turbo oil feed.
10. Blow off valves, adjustable waste gate.
11. Ignition. Aftermarket. Period. Stock will not tkae much over 4 PSI.
12. Plugs. 2 stages colder then stock. Just like your running NOS.
13. Engine mounts. STRONG ONES. Same goes for the tranny mount.
14. Drive train. Up to you. I would upgrade and or rebuild everything under the car. Get rear LCA's, pan hard bar, ect that the v8's have to get when they start building up power.
15. Run a cooler thermo. 180 should do it.
I know there are other things but I am spurting this out real quick.
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Ions91Z28
Jan 13, 2002 07:22 PM
89transam
Jan 1, 2002 12:57 PM
stevenmh
Sep 26, 2001 06:00 PM
aziroc
Aug 16, 2001 11:36 PM
