Got Me Headers!!!!!!!!!!
Old Feb 21, 2002 | 10:55 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
they came UPS yesterday
it looks like they should fit............they look bigger in person.........................but they look like they will clear everything just fine
cant wait to get the Z28 so i can drive that while the exhaust shop does my custom exhaust work (y-pipe, and a straighter pipe to the muffler............................need to also weld a pipe on so i can still run the EGR.............
Old Feb 21, 2002 | 11:04 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
congrats on getting head.......ers
did they come w/ O2 sensor bung?
Old Feb 21, 2002 | 11:24 AM
sadly they did not come with bung nuts
i have to put the bung nuts in myself
yeah there definatley not emissions legal as is.............................so i'm gonna make them legal.............just have to cut a hole in the middle passenger side primary to weld a pipe on for the EGR.....................then gotta put a bung nut on
all in all sounds like an easy task
Old Feb 21, 2002 | 12:00 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
So I take it that means you will have to drill a........bung hole!
Old Feb 21, 2002 | 02:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I wonder if you'll need a heated oxygen sensor when you get these installed. It's a common V8 thing... headers run cooler than manifolds, and in the "stock" location, an oxygen sensor won't reach it's operating temp with headers. So the V8 guys buy the heated oxy sensor... it's the same sensor, but with two extra wires. One wire goes to ground. The other wire goes through a relay and a fuse to the car battery. When you turn the car on, you turn the relay on (probably via the ignition fuse, which is hot when the car's starting), which turns on the oxy sensor, which heats the oxy sensor.
Old Feb 21, 2002 | 05:54 PM
Jaren Bon Jovi's Avatar
Teal, let me know where you got the gaskets and all the other stuff to install the headers. I saw in the Jugs catalog they sold Bolt-On collectors with oxygen sensor fittings. Let me know how everything goes, because I cant wait to get mine installed in the summer. Peace.
Old Feb 21, 2002 | 06:06 PM
Xenodrgn's Avatar
19991teal... where are you taking your car to have the exhaust done? Somewhere up in Brick or closer down here? I need to find a cheap reputable shop around here that'll do it for me when I get mine.
Old Feb 21, 2002 | 09:25 PM
well, the headers i am going to put on myself.......the exhaust work.......wherever will take it.............i think meineke will probably do it for a fair price........thats where i had my flowmaster put on
TomP, that sounds like a theory...........just might have to do that! other wise my O2 sensor will give a reading that will calibrate wrong with the ECM
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
