No start V6 HELP
Old Feb 21, 2002 | 04:44 PM
maverick544's Avatar
No start V6 HELP
I took my car out of my garage to fit some parts on it, well anyways I can't start it now when I try to jump it. I put some gas in the tank cause it was real low but still no start. I can turn the key and the car is trying to start but seems that it can't, it comes closet to starting when it starts to stutter but still no start. I gett fed up now and got to get to work, not with the car though. I know it shouldn't be flooded cause I coulnd get it started before too. I just want my baby back up and running. I dont think its flooded cause it would have dryied up by now. I think I may change the spark plugs anyway though. what else u think it could be. HELP Please!
Old Feb 21, 2002 | 05:37 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if battery is completely dead, it will not jump. check fuel pressure (key on-engine off ), is there any spark?
edit: try starting in nuetral, could be the safety switch
Old Feb 21, 2002 | 06:36 PM
BitchinRS's Avatar
I ran my tank realllllllyyyyy low one time and had to let the fuel pump prime 3 times. Turn the key to the on position but don't start it. Wait for the pump noise to go a way. Turn key off and repeat a couple times. Then try to start.
Old Feb 22, 2002 | 06:59 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Sounds like the same problem I had last month. Culprit was a dead coil.
Old Feb 22, 2002 | 04:42 PM
My Dad told me I got to charge the battery a little just to jump it, cause the battery is pretty much fully dead. SO now its time to find the battery charger
Old Feb 22, 2002 | 06:03 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I think you've fouled some spark plugs. My car does that cause I sits for a while and I start and move the car for a few minutes. Oh I cant wait to drive the car daily.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
