TPI/ MPI sensors
Old Mar 3, 2002 | 10:25 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
TPI/ MPI sensors
i was looking through a NAPA catalog in school and every sensor i looked up for the 2.8/3.1 MPI motors and the 350/305 TPI motors were the same part number..........
so i am thinking..........theoretically..........that if you want to swap a MPI motor for a TPI V8......can you keep the MPI harness......lengthen it............and use it on the TPI with just a different PROM??????
Old Mar 4, 2002 | 09:37 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
How would you add the 2 extra injectors?
Old Mar 4, 2002 | 10:27 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, sensors are sensors, doesn't really matter which engine they're from. In fact, a lot of the ignition parts are also the same! A lot of the wiring is the same, too... but like was said, you need to add the extra injectors. I think if you search the archives, you'll find info on this; I recall someone asking this question a while ago.
Old Mar 4, 2002 | 11:27 AM
good point.............i figured there was something i was missing
theoretically though, if you are still using a multi-port batch fire system, couldnt you just splice them in...............
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
