tire pressure on a digital gauge
Old Mar 5, 2002 | 05:20 PM
WaynesRS's Avatar
What should it be ? Thanx !
Old Mar 5, 2002 | 05:47 PM
BitchinRS's Avatar
same as if you were using an analog tire gauge. The hanyes / chilton's book should have the corect tire presure. I think it's either 32 or 34. Well at least that is the rating for most pasenger cars.
Old Mar 5, 2002 | 07:16 PM
Belker's Avatar
Thye recommended tire pressure should be written on the side of the tire.
Old Mar 6, 2002 | 12:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually, on all the tires I've seen, that's the max pressure.
Old Mar 6, 2002 | 10:39 PM
Belker's Avatar
i just went out and looked at my car and it only lists Max. Tire Pressure 44 psi. However, I looked at my neighbors car and it listed Recommended Tire Pressure 30-35 psi. I also remember that the tires on my previous car had a recommended tire press range. So ... I admit that my previous post may have not been very helpful.
Not that this is pertinent to the discussion (but for amusement), the tires on my bicycle list ranges for on-road, off-road, with-suspension, AND without-suspension.
Old Mar 6, 2002 | 10:48 PM
WaynesRS's Avatar
Originally posted by Belker
i just went out and looked at my car and it only lists Max. Tire Pressure 44 psi. However, I looked at my neighbors car and it listed Recommended Tire Pressure 30-25 psi. I also remember that the tires on my previous car had a recommended tire press range. So ... I admit that my previous post may have not been very helpful.
heh
What the hell is my neighbor doing bending over looking at my tires so close on my car for ? :sillylol:
THANX MAN !
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
R3500
Aug 17, 2015 12:16 PM
