Using larger valves
Old Mar 13, 2002 | 09:55 AM
svgeek's Avatar
Using larger valves
I finally received the set of heads for my 2.8 project.
They have the smaller valves. A number of places with 60 deg V6 info state that the only difference between the small valve heads and the HO ones are the size of the valves.
Has anyone done an upgrade and installed larger valves?
I am wondering if I need to have the valves seats replaced in order to use the larger valves.
Thanks.
Ben
Old Mar 13, 2002 | 10:56 AM
Camaro_hunter_d's Avatar
Your gonna haft to take it to a machine shop and have them mill the head for the larger valves.
Old Mar 13, 2002 | 06:21 PM
V6camaroman's Avatar
i have bigger valves in my 2.8 my cousin had done when it was rebuilt. im not acatualy sure what size they are. i would have your heads taken to the machine shop and have them fully rebuilt with bigger valves
Old Mar 14, 2002 | 09:37 AM
KED85's Avatar
IF ya really wanna do this.
GO TO ANY HEAD SWAPPING PLACE
or WRECKING YARD.
Options.
Cracked, throwaway 2.8/3.1/3.4 heads
Throw away MPFI engines (tons of THEM), take those heads strip out valves
SWAP YOUR HEADS for the Over The Counter rebuilt MPFI heads.
You NEED new springs
NEW GUIDES
Griding/seating.
Swap in the "larger" valves.
Make SURE the back cutting is done on the VALVES, TOO!!
I once had a pair of MIS MATCHED SBC chevy heads.
I wanted the better of the two numbers.
I "shopped" around until I found an engine head shop rebuilder that would look at my swap option.
I paid $75 for my other 1969-1970 Z-28/LT-1 #186 head and gave him the other head, in trade. Big deal, I had the matched set. I paid $25 for that lone head at a swap meet.
Old Mar 14, 2002 | 10:29 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I heard that the machine work to put larger valves in is very expensive; you might want to count those heads as a loss (or sell 'em on eBay) and do what Karl suggested.
Old Mar 14, 2002 | 11:16 PM
svgeek's Avatar
Thanks for the ideas and suggestions. I'll see what the prices are for putting in large valves seats etc. If it's too expensive, I'll probably just port the heads I have and put in larger valve heads some other time.
Ben
Old Mar 15, 2002 | 11:38 AM
KED85's Avatar
Wisest is to shop/swap for MPFI fresh rebuilt heads from a head rebuilder.
Phone & ask, that's all I did & I won.
Paid little more but, I still won at a dirt cheap price.
Get your machinist cost & you'll be looking for the head rebuilders real quick!
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
drptop70ss
Oct 4, 2015 09:44 PM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
