Help Asap !
Help Asap !
I took my cap and rotor off . I got the new rotor on , no problemo ! But the cap when it goes on , it wants to move from side to side ( only in one direction) it moves from east to west . How do I get this fu(K*r to go on there tight .I had this problem when I took off my cap a few weeks ago to check it out , but on the third try I got it to fit right .
Car: 1986 Firebird
Engine: 2.8 V6
No problem. The reason the cap isn't going on right is because it's not seating around your spark module correctly. That's the square cutout on the bottom of the cap, where the two-pin and four-pin connectors come out. Look at the module (with the cap off) with a flashlight- you'll see a groove. The cap should fit in this groove. Usually it involves lifting the cap straight up, and putting it back on "straight down". If you can crawl on your fender so you can see the groove and the cutout of the cap, you should be able to get it on.
Yeah , its on there right . I have been doing just like you said , i have my feet off the ground and I have been hovering on the fender .. I just can't figure out why this **** wont go on there .
I think the holes on the metal base are stripped
errrrrrr Im scared If I put my accel cap on there it will eat my rotor up and my rotor will get ate up to . I might just put the old crap back on there and and keep my spare cap in the trunk
errrrrrr Im scared If I put my accel cap on there it will eat my rotor up and my rotor will get ate up to . I might just put the old crap back on there and and keep my spare cap in the trunk Thread Starter
Well , I put my old cap and rotor back on , I didnt wanna take a chance of eating up my cap and rotor . I drove it alot and it did fine . I will mess with the accel one another day .
