pic of my intake
Old Mar 16, 2002 | 02:38 PM
91FIREBIRDGT's Avatar
Car: 1991 Firebird
Engine: 3.1LV6
pic of my intake
this was taken before i made it into a CAI .
if it doesn't show go here:
http://www.geocities.com/lilsap23/intake_part_1.jpg
Old Mar 17, 2002 | 07:04 PM
Car: 1991 Firebird
Engine: 3.1LV6
any opinions?
Old Mar 17, 2002 | 10:09 PM
KED85's Avatar
Yeah, I can't see it.
Old Mar 17, 2002 | 10:49 PM
Car: 1991 Firebird
Engine: 3.1LV6
copy and paste the URL
Old Mar 17, 2002 | 10:59 PM
RPS's Avatar
RPS
Geo cities wont let you directly refer a picture by a link... here you go
Old Mar 17, 2002 | 11:07 PM
Car: 1991 Firebird
Engine: 3.1LV6
ok thanks....any opinions?
Old Mar 17, 2002 | 11:48 PM
KED85's Avatar
Isolate area with plexiglass & let in more fresh air
Old Mar 17, 2002 | 11:53 PM
Car: 1991 Firebird
Engine: 3.1LV6
i've already done something like that. I extended it so the filter sits below the "battery tray" and directly behind the turn signals (91-92 f-bird bumper) where it can get fresh cold air.
Old Mar 18, 2002 | 09:27 AM
KED85's Avatar
Again, Isolate it from the HOT engine air.
Make it outta cardboard (template).
Transfer pattern to Plexiglass.
That will make a BIG difference.
Get more air, there.
Make underside scoop.
Raise corner of the hood (see plastic black screw on the left?)
Twist it higher.
Lower the door for the headlight.
I'm even gonna slice a hole thru the hood brace support for more direct air to my A/C top scoop.
Raise hood, it helps!
I finally got a dirty filter!
I can feel the power as I pass cars going 75+.
Old Mar 18, 2002 | 01:01 PM
kessler89/2.8's Avatar
Car: sold the Z now i'm drivin a 81 toyota celica and an 01 Suzuki TL1000R
Engine: 90degree 998cc V twin
Transmission: 6 speed
where'd you get that polished intake tube and how much??
Old Mar 18, 2002 | 08:59 PM
Car: 1991 Firebird
Engine: 3.1LV6
one half of the tube is from a Honda Civic 96-2001(the part closer to the filter) the other half is a Universal j-bent air intake pipe (the one attached to the throttle body) You can get these parts at any place that sells intakes. Pep Boys, Kragen, Auto Zone, etc. I used the civic intake only because it has the right bend and length i needed to put the filter below the battery tray.
stalkier
Dec 6, 2015 11:25 PM
1985chevydude
Aug 20, 2015 12:29 AM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 12, 2015 11:33 AM
Jake_92RS
Aug 11, 2015 10:39 AM
