Smog pump help PLEASE
Old Mar 26, 2002 | 03:56 PM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I have a factory 3.1 V6,no mods.I want to bypass the smog/air pump without affecting the performance or longevity of the engine.Is there a way I could use a shoter serpentine belt to bypass this pump in the routing of the engine?
Ken
Old Mar 26, 2002 | 06:53 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you go to a junkyard, check out some of the 87-89 2.8 f-bodies. Those that came from the factory without AIR pumps have an idler pulley in it's place. It bolts right to the engine! "It's been a while", but I think the rear support goes to one of the exhaust manifold bolts, and the front two bolts go to the alternator bracket. Bring Liquid Wrench (or PB Blaster) with you to the yard...
In fact, I think you can order that pulley from GM.
Old Mar 26, 2002 | 07:36 PM
86bird_28v6_5spd_ramair
Guest
Posts: n/a
I was able to get a smaller belt for my 86, it just happened in 86 only the stick came with one so it was an easy belt change.
And I am in Toledo Ohio, so no smog ****, especially since I live near 3 oil refineries and a coal burning power plant and a nucular power plant few miles down the road.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
