stuff to lighten up cars weight??
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
i already took out backseats and spare / jack
anything else i could do to lighten up the car a lil bit?
you can take out the sound deadning pads that go under the carpet, buy lighter wheels, buy a fiberglass hood.
oh and you can read a tech article also
did you weigh the rear seats? how much do the weigh???
Car: 1986 Firebird
Engine: 2.8 V6
I actually disagree on the padding below the carpet. It weighs nothing.. maybe 2 pounds. When I replaced my carpet, for kicks, I separated the old padding from the old carpet, and picked it up. The old padding was extremely light. I wouldn't bother ripping apart the car just to pull it. Hell, you could skip lunch, and it'd probably be the same weight difference!
If you're like me, and hate air conditioning, you could always pull that to save weight. Wooden subwoofer boxes add a ton of weight; if you have one, you could remake it with fiberglass.
Car: 91 Camaro RS
i need some serious and realistic answers
please no jokes
are there anymore thoughts on how to get rid of some wieght other then A/C?
plus i dont wanna do somthing thats a pain in the *** or a hard time just to save a couple pounds
please no jokes
please no jokes
please no jokes
Did you read this artical - https://www.thirdgen.org/newdesign/t...ngpounds.shtml
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
jc whitney has fiberglass front ends. relocate batt to where spare used to be & vent to outside. lighter wheels. read the above article. loose a/c compressor if not used.
You draggin or something, If you are strip everything out but the essentials. But street try rippig the stereo out thats about 5lbs, AC is about 45lbs passenger seat about 40+lbs. The plastic that goes around the back is easy to remove too, I'm sure thats worth some lbs too.
lol ... go and find someone who is less than 100lbs to drive the car and teach him/her how to drive im sure that'll reduce the weight a lot...
everyone needs a j/k once in a while...
if u are draggin ... then remove everything interior except the drivers seat both the dashpad and passenger seat weigh a lot...
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
NBrehm
Aug 5, 2015 07:57 PM
