question on thermastat gasket
Old Apr 2, 2002 | 07:01 PM
WaynesRS's Avatar
Today I changed my thermastat to a 160 . I went to the parts store to pick up a gasket .The old gasket that I took off was a round rubber one . The only one that part store had , and said it worked in the computer was like a paper one , and its much bigger than the rubber one . I put it on there and it seems it will do fine , but I have not driven it yet . How will this different gasket do ? I have not driven my car sence I started on my injectors , today I just finished putting everything back together . Its a long story , but the parts store has not been open when I need it to and there is dangerious insifulitus (spelling?) mosquitoes out down here now . If you get bitten by one carrying the disease you can die .So my time has been real limited , anyway .Thanx guys !
Old Apr 3, 2002 | 08:11 AM
WaynesRS's Avatar
ttt:lala:
Old Apr 3, 2002 | 09:56 AM
Drew's Avatar
Dont sweat it... the stock tstat uses a oring around the stat, as long as the paper gasket is compressed between the waterneck and the intake manifold it'll work fine.
Old Apr 3, 2002 | 12:08 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How was the round rubber one orientated? I've always had a paper gasket on mine, and thru many scrapings, the sealing surface of the water neck is damaged. I need to slap a ton of sealer on the gasket to keep it from leaking.
I'd love an O-ring. Was it on the 'stat like Drew said? I thought that was only for 90-up 3.1's! See if you can get a bottle of gasket sealant; I use the Permatex Hi-Tack red, in a little metal can (with a brush in the lid). You could also use blue RTV (in a tube) to make a gasket, but don't overtighten the bolts, or you'll squish all the RTV out.
Old Apr 3, 2002 | 01:24 PM
Camaro_hunter_d's Avatar
if you see any cold temps get a 180. have a paper one on mine and has been there for almost a year..hell even a little over now...
1992 Trans Am
May 10, 2023 07:19 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
redmaroz
Aug 16, 2015 11:40 PM
