Has anybody seen the Cragar Edge?
Car: 1982 Z28 Camaro
Engine: 1988 350 H.O.
Transmission: TH-350 w/ shift kit/stahl converter
I really want these wheels but they are for trucks and suv's, but I've also seen many f-body rims on s-10s.
This is the info, I'm clueless so can somebody please tell me, will these fit? and if not what would I need to do to make them fit?
Available Lug-patterns :
5x114.3mm (5x4.50") 5x120mm 5x120.65mm (5x4.75") 5x135mm 5x127mm (5x5.00") 5x139.7mm (5x5.50") 5x150mm 6x114.3mm (6x4.50") 6x135mm 6x127mm (6x5.00") 6x139.7mm (6x5.50")
Available Hub bore sizes :
2.86", 3.071", 3.425", 4.342"
Available offsets (Corresponding backspacing) :
+0mm (4.50") +14mm (5.05")
Heres a link too, http://www.wheelsmarket.com/cragar-w...-and-suvs.html
Car: 86 Camaro Z28
Engine: 383
Tire
I love those wheels also. Don't love the price though.
They should fit as long as you get proper lug-pattern. I believe it should be 5x4.75". Please double check though.
The backspacing will depend on how big of tire you are going to use. I was thinking of getting the 5" backspace since I plan on getting 275/40/17.
Let me know if you find these wheels cheaper anywhere else.
Thanks,
Rob
Thanks,
Rob
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
nice rims, a bit steep though
if you can't figure out what the spacing is look at a gm service manual it might tell you
Elephantismo
Feb 13, 2019 12:51 AM
dimented24x7
Sep 17, 2015 06:58 AM
