tire question
Old Feb 22, 2005 | 02:34 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
tire question
ok this tire shop in toronto said on a lowered camaro we cant do a 225 wheel cause it will rub...i know not alot of you guys have it as low as mine..but i know some of you have the 2' drop...what size tires do you guys have up front? cause i think this shop has no idea what they are talking about
Old Feb 22, 2005 | 04:52 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
225? That is pretty narrow, actually smaller than the tires that came on the stock 16s. It could depend on your backspacing of the rims I guess. But if they are correct for the car, you should be able to go much wider.... I have the pro kit on the Z with 275 and they never rub even on bumpy roads. Also have the pro kit on my rs, and with 245 on the stock 16" rims, there was plenty of room.
If you are talking stictly turning and the tires up front, then I would just say get use to taking wider turns! You're going to have to anyways if you go with anything smaller narrower....
Old Feb 22, 2005 | 05:19 PM
slammed_z's Avatar
Car: 1985 camaro
Engine: 305 H.O
Transmission: auto
well im not gonna go into this again why i cant go bigger then 225...but on my rims i got 215..which are way to small..like it looks like it barely mounted on the rim...so thats why i want 225..cause i cant go alot bigger of an overall diameter then that...but ya i dont get why they said i cant go 225..like a 225 would just fit the 8.5 wide rim just perfect so i dont get that..like if i couldnt do 225 i shouldnt be able to turn my rims already with the rims alone
Old Mar 11, 2005 | 06:11 AM
uwilluz1's Avatar
Car: 84,89,00,02 t/as 71vette sierra
Engine: 310,350,383,383
Transmission: bw t5, trem t5, hurst 6 spd
Axle/Gears: 4.10, 3.42, 3.73, 3.73
it all has to do with your height to width ratio. you could go with a 225 but maybe in a 35 or 40 instead of the stock 45. i had the same problem in my 00 when i dropped it 2 inches with the eibach pro kit. im running 235/45/17 front and the stock 275/45/17 rear both on 17x9's. they look damn close. noone just looking at them can tell the diff. but it was the height of the wheel that caused the rubbing, not the width of the rim. you can run your stock rim, just try finding a shorter tire wall. i know with the abs cars you have to be within 5% of the wheels spinning aspect or it will throw off the abs. hope this helps
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
69 Six Pack
Oct 5, 2015 07:51 PM
redmaroz
Aug 16, 2015 11:40 PM
