wheeels!
Old Dec 3, 2006 | 12:35 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
wheeels!
ok so im putting some american racing 17" wheels on my maro, there off a 4th gen and they have correct backspacing for a 4th gen, what i need to know is what thickness wheel spacer i need for the front and the rear to put them on a 3rd gen"?
Old Dec 3, 2006 | 08:12 PM
Car: 1979 Malibu
Engine: Blown LSx
come on some one had to know TTT!
Old Dec 4, 2006 | 01:03 PM
19redbird89's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.23 9 bolt
it should be a 2 inch adapter. That is what I have seen most of on the board. You could also go with 2 in the front and then less in the rear with some inner fender massaging. I do not know a whole lot about any of it but I have 2's on my car and about to go to a 17X11 wheel and i am looking at some fender modification. hope this helps.
Old Dec 4, 2006 | 06:14 PM
Car: 1979 Malibu
Engine: Blown LSx
well my car is keeping the stock ride height, so i dont think fender lip clearance will be an issue, thanks for the reply
Old Dec 5, 2006 | 01:07 PM
Car: 1979 Malibu
Engine: Blown LSx
anyone else??
Old Jan 24, 2015 | 09:35 AM
85blackgoldtpi's Avatar
Re: wheeels!
2" spacers sound rediculous . Id be worried about snapping studs with all that leverage on the studs. U will also need longer studs probly .
Old Jan 24, 2015 | 10:53 AM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: wheeels!
This isn't an issue with bolt on spacers. The bolt ons bolt to the hub, then the wheel bolts to the spacer. Even some of the autoX/RR guys use them. Thats about as much stress as you could put on them.
Old Jan 24, 2015 | 10:59 AM
Re: wheeels!
Ya they may be a bit better than the floating ones . If it was me I would just get a proper wheel for the car . IMO .
Old Jan 24, 2015 | 11:43 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: wheeels!
I think he figured it out in the past 8+ years since his last post.
Old Jan 24, 2015 | 05:48 PM
Car: 92 Camaro RS
Re: wheeels!
Just saw it at the top of the list, didn't even look.
torqueaddict
Feb 21, 2012 07:54 PM
z28man350
Aftermarket Product Review
Feb 11, 2012 07:55 PM
tinman89
Dec 30, 2009 07:16 AM
nos_rida
Nov 8, 2006 07:17 PM
