Wheel Question
Old Apr 17, 2007 | 02:33 PM
sixpackrt's Avatar
Car: 87' Firebird Formula
Engine: lg4 305
Axle/Gears: 3.73's finally
Wheel Question
I would like to buy a set of torque thrust 2's but here is my dilemma, I guess I am old fashioned but I want to rotate my tires front to back and side to side. My goal ist to buy a set that are all the same size and offset. Like a set of 17x8's or 17x9.5 with a nice wide tire all the way around. I know that usually the fronts need to be spaced out different but couldn't I just buy like a set of four with the same offset and just buy 1.5 or 2 inch bolt on wheel spacers for the front then I could rotate them like normal? Please let me know how I could do this without buying separate fronts and rears. Any help is greaty appreciated. Thanks, Bret
Old Apr 17, 2007 | 02:49 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
Re: Wheel Question
I'm looking at the same problem, with a '90 Formula.
For some reason, PMD saw fit to use different off-sets,
such that the front & rear wheels are not completely
interchangable. I think I've seen tech data here on
the board, that indicates the basic problem is different
wheel to wheel axle length between front & rear.
I asked some preliminary questions at NTB the last time I
was there for daily driver service. The answers were:
1) Spacers are the least desirable solution, since they alter the
load distribution on the lug bolts.
2) Ask the manufacturer of the desired wheel how they address
this problem. Some have universal fit rims, but the axle length
differences will be transferred to the ground.
Check the Tech Articles:Suspension:Wheels & Adapters post on
this board -- lots of good info.
Keep us posted.
I'll be interested to hear the board expertise weigh in on this.
Old Apr 17, 2007 | 04:14 PM
sixpackrt's Avatar
Engine: lg4 305
Re: Wheel Question
If nothing else, could I buy a set of four fronts and put them all the way around? I know they may stick out a little bit more in the back but I suppose that would probably work also? I guess rather do what I stated in my first post.
Old Apr 17, 2007 | 06:07 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: Wheel Question
17x8's with something like a 245/45 or 255/45 would be good.. with 4.5" backspacing.. some people run 17x9.5 with 275/40's on the front and back.. 5.5" backspacing..
no need for spacers unless you are buying 4th gen wheels..
i ran 17x8's on my TA for a while.. had to ditch them cause my 3" rear studs wouldnt work with my lugs..
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
