Camaro Wheel help
Car: 83 Z28 Camaro
Engine: 5.3L L33
Transmission: 4L65E
Axle/Gears: GM 12 bolt 3.73
Camaro Wheel help
Hi Does any one have any suggestions on were i can get some aftermarket rims for my 83 camaro.
What is the max size that will fit. I was thinking of going with 18-8. The only wheels I have been able to find are the Iroc replica rims. I really dont like them very much.
Any help would be nice. Thanks
I hope that this is the right thread to post this ? in.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Camaro Wheel help
what style wheel are you looking for and what is the budget?
If you are searching for wheels at sites for a 83 camaro, you will find little. What you need to look for are wheels with 5x 4.75 bolt spacing, and a zero offset/4.5" of backspacing, for a 18x8. You can go wider if you want, and adjust the backspacing accordingly
4th gen wheels and c5 c6 corvette wheels are popular, but require spacers.
The problem is, after you get away from factory style 1 opc cast wheels, the cost skyrockets. A nice set of 2 or 3 pc billet wheels can cost upward of 2000 or more.
