295/30/18 vs 295/35/18
Car: 1988 IROC-Z
Engine: 355ci SBC, Holley carb
Transmission: 5 speed manual
Axle/Gears: 4th gen Z28
I've got one of my wheels painted and will be looking to put tires on them as soon as i have all 4 done. Right now, the plan is to run 275/40/17 tires on the front rims. For the rears, i got a killer deal on (1) like-new 295/30/18 Yokohama AVS Sport. The preferred size is a 295/35/18 and i'm wondering if running this smaller series tire will work OK. At this point i can either find another Yoko to match, or sell the one i have and look for a matching pair.
Let me know if anyone's had any experience running this size.
Thanks...
Thanks...
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Re: 295/30/18 vs 295/35/18
Does this mean you are running 17's on the front and 18's on the rear?
I'd say go with the size you want.
275 40 17 is 25.7" tall
295 35 18 is 26.1" tall
Car: 1988 IROC-Z
Yeah, i have a stock set of Z06 wheels so 17 front, 18 rear.
I guess i'll have to get the 1 295/30/18 Yokohama i have mounted so i can look at the rim & tire combo on the car and make a decision from there.
If i like the look, i'll get another. If i think the tire looks too minimal in the
wheel well, i'll sell the one tire and pick up a pair of 295/35/18's.
Thanks Project.
Thanks Project.
Car: 89 IROC
Th 295 30 18 Yokahama is too short. It's only 25.1" tall. You need a tire close to the stock height of 26".
Sell the Yokahama and go with the 295 35 18.
A short rear tire will throw off your speedo (unless you change speede gears).
The idea is to have front and rear tires the same height (or close to it)
Good luck
Good luck
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
agreed, get the 35 series tire, the sidewalls will match better and look better
i wish i would have done that on my setup but i couldnt find my brand of tires in the size i wanted
Car: 1988 IROC-Z
Thanks for the info guys. I've still got some painting to do on the rims before i'm ready for rubber. Thinking i'll most likely sell the 295/30 and go with the 295/35. Besides, i'm having a tough time finding another AVS to match it.
rce2win
Wheels and Tires
Nov 17, 2009 09:57 AM
Justin89Formy
Jun 18, 2007 05:43 PM
iroczrockz
Nov 6, 2004 10:26 PM
