What Wheels & Tires Will Fit 87 Z-28
Old Nov 17, 2008 | 12:41 PM
Proud Marine Pa's Avatar
Car: 87 Camaro Z-28, 2006 Mustang GT
Engine: 305 TPI Camaro, 4.6L Mustang
Transmission: Auto Camaro, 5 Speed Mustang
Axle/Gears: 3:23 Camaro, 4:10 Mustang
I have a stock 87 Z-28 and it has the stock 15" rim's & tires on it, I am in the process of replacing the rims and tires and was wondering if 16's" will fit if so what wheel & tire Combo would work best for me? It is a street car that will be upgraded with 4 way disc brakes, Sway bar upgrades and possibly Tubular A-Arms... Any Suggestions Would Be Greatly Appreciated
Thank You
Jeff
Old Nov 17, 2008 | 03:53 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: What Wheels & Tires Will Fit 87 Z-28
The only way you'll have a problem with 16's is if you go crazy with the width (like 10" wide). Heck, even most 17's fit without any issues what-so-ever. I'm going to be getting 17x9.5 with 275/40/17 tires on all fours which fit without any issues.
Instead of going with tubular A-arms get a good set of shocks and springs or at least some SFC (subframe connectors).
Since your thinking about swaybars and your vehicle is only for the street, just stick with the GM bars. They are a ton cheaper than the aftermarket and they are more readily available.
Any other questions feel free to ask,
Mike
Old Nov 17, 2008 | 04:57 PM
So now I can expand my search. I am still at a loss as to what size tires?? I was thinking something in the 245/45ZR16's or something around there
Thanks for the Info it is greatly appreciated.
Old Nov 17, 2008 | 09:22 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
The stock size on the cars is 245/50R16s. Those would be your best option, IMO. With 17x9s (275/40R17s) you'll need a set of 2" bolt on spacers front/rear or a set of spacers front and a 4th gen rear end. Or, you can find some 17x9s that fit the 3rd gen offset. You can run properly offset 17x8s without spacers. Most use 245/45R17s with those I think.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
overdriv
Aug 20, 2015 03:52 PM
forstral
Aug 19, 2015 03:20 PM
