Got Vette Wheels??...Post pics here...!
Old 11-24-2011, 12:29 AM
  #501
killermaro's Avatar
Car: 87' Iroc Z
Engine: TPI 350
Axle/Gears: Borg Warner 9 bolt and 3.27's
Re: Got Vette Wheels??...Post pics here...!
I want to steal yuor exact setup. Minus the rivets in the wheels. What size wheels do you have(front and rear)? Also did you have to modify anthing for them to fit? Also what size spacers did you use?
One more question. What size drop is that and are those the eibach sportline springs? Do you have a down the side picture that shows a better pic of the stance?
Old 11-24-2011, 12:31 AM
  #502
killermaro's Avatar
Car: 87' Iroc Z
Engine: TPI 350
BTW my car is the exact same color without the stripes on the hood. I have the little vents.
Old 11-24-2011, 02:30 PM
  #503
CamKid1992's Avatar
Car: 1992 Camaro
Engine: HSR 355, afr 195s, xfi280, Holley e
Transmission: t-5
Axle/Gears: Braced 10 bolt Auburn and 3.73s
18 by 10.5 in rear with 305's and 17 by 9.5 with 275,s and I have sportlines. I have some pics but they won't load from my phone. I have 2.5in up front and 2in in the rear as for spacers. The fronts don't need to be that wide but wouldn't go to much less. I have qa1 adjustable shocks in rear. And agx adjustables struts up front.
Old 11-26-2011, 02:35 PM
  #504
killermaro's Avatar
Car: 87' Iroc Z
Engine: TPI 350
cool. you didnt have to modify the fenders at all?
Old 11-26-2011, 03:16 PM
  #505
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Nope, not yet I need to roll the fender lip and my tires show it but I haven't yet
Old 11-27-2011, 02:14 PM
  #506
killermaro's Avatar
Car: 87' Iroc Z
Engine: TPI 350
Oh ok. Hopefully I will have everything I need soon.
Old 12-06-2011, 10:05 AM
  #507
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Originally Posted by GTA1990
GTA running C6s. Standard 18/19s with 255s up front and 295s on rear. LS1 Brakes on front. 1 coil cut off of front and 1 1/2 coils off of rears. Moog springs. No isolators
Rear could do with another half coil and perhaps a slightly thicker tyre wall
Pics at my local sikh temple - enjoy!
Looking at a set of these locally & was thinking same tire combo.
Old 12-06-2011, 03:58 PM
  #508
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:43 LSD
can recommend the tyre sizes. Fronts only rub evey so slightly on full lock and the rears fill the wells well. Straight rear shot is just plain mean!
Mine needed ever so slight messaging on the rear well bottoms and should I lower the rear more I'll probably get the arch lips rolled.
I've got pirelli p-zeros on the rears; not sure if its the tyre compound or tyre size (or perhaps both) - but def. an increase in road noise!
good luck to you
Old 12-08-2011, 06:49 AM
  #509
Patrick Day's Avatar
Rears Corvette ZR1's 17x11 /295zr40 And 3in spacers ,
Nead 2 and 1/4 spacers.
But now have decided to go a different route
Thats why the fronts are not on.
Attached Thumbnails Got Vette Wheels??...Post pics here...!-016.jpg   Got Vette Wheels??...Post pics here...!-013.jpg   Got Vette Wheels??...Post pics here...!-001.jpg
Old 12-08-2011, 10:46 PM
  #510
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Here are some updated pictures... Nothing special just angle shots in my driveway.
022.jpg?t=1323405095
016.jpg?t=1323405030
IMAG0800.jpg?t=1323405274
Old 12-20-2011, 10:01 PM
  #511
sempco09's Avatar
Car: 1989 Camaro
Engine: Modified 350 bored out to about 360
Originally Posted by Z28FAST1
Measurements are posted above per OE Wheels. I only have these pics from my phone for now.
Man that combo is SWEET!!! Ive been looking for new wheels for my 89 and DAMN! just a heads up i might have to steal them
Old 12-22-2011, 11:23 PM
  #512
•3rdgenbeast®'s Avatar
Car: !984 Z28
I am sold on vette wheels for sure.
Old 12-22-2011, 11:30 PM
  #513
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Old 12-24-2011, 07:30 PM
  #514
85IROCzzz's Avatar
Car: 91 Z28
Just got them on and snapped some quick pics. 245/40-18 on the front with a 2" spacer, 285/30-19 on the rear with a 2.25" spacer. I think I could have gotten away with a little thicker on the rear, maybe a 2.5" but it looks good. I think lowering my car would bring it all together and make it look sweet.
The old wheels were the 16" American Racing IROC wheels, originally $195/pc from summit. I would sell them for 500 for the whole set if anyone is interested. They are immaculate except one of them has maybe a 1/2 centimeter curb rash spot on the lip. Pics available upon request.
Old 01-02-2012, 09:58 PM
  #515
silverado638's Avatar
Car: 1985 IROC-Z
Transmission: borg warner 5-speed
Axle/Gears: stock
I'm probably repeating this question but I just wanna make sure i'm hearing it right that if I would want to run 18x9.5 up front and 19x10 in the back all I would need is 3" spacers all around and no other modifications to the wheel wells or anything? My suspension is completely stock and i'm running a stock 3rd gen rear. I hope i'm not making anybody angry but I just wanna double and triple check before I go droppin a bunch of money on wheels, tires, and spacers.
Old 01-03-2012, 12:29 AM
  #516
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
False, you would have to at minimum roll your renders probably pull them also. I'm running 18by10.5 and mine need rolled. 19's would be a bit much. And I'm running smaller spacers shouldn't need 3in.
Old 01-03-2012, 01:33 AM
  #517
RPOL98's Avatar
Car: 90 IROC
Engine: 5.7L TPI
Axle/Gears: 9-bolt BW
required spacer width would also depend on the backspacing (or offset) of the wheels you purchased.
Old 01-03-2012, 05:51 AM
  #518
Car: 1985 IROC-Z
Axle/Gears: stock
well i was gonna get some stock vette wheels so whatever the backspacing and offset is for them and what size wheels can i go with so that i don't have to roll the fenders. i knew i was gonna have to run spacers but i don't wanna have to roll the fenders or any of that other good stuff.
Old 01-03-2012, 10:19 AM
  #519
Boreen's Avatar
How do i upload a picture?
I put 18x9.5 C6 ZO6 Wheels on the front and rear of my car with 245/40 tires. Love the set up, and so does everyone else. 2" Spacers all the way around also, could use about a 1/4" More in the front as its close to the inner fender at full crank. My car definitely needs to be lowered an inch or two for sure though.
Old 01-03-2012, 04:56 PM
  #520
85IROCzzz's Avatar
Car: 91 Z28
The only definitive answer you are going to get is by mocking up your new wheels where you want them and measuring back to the hub. Everyone's setup is different so what works for one may not work for others. Measure that and then order spacers accordingly.
Old 01-03-2012, 05:03 PM
  #521
85IROCzzz's Avatar
Car: 91 Z28
Click "Go Advanced" below and then lower on the page click "Manage Attachments" and upload the ones you want to use.
Alternatively you can upload your pictures to a image hosting website (photobucket, etc.) I personally use www.imageshack.us. Then make sure you copy the link to the the actual picture (the link should end with .jpg or what ever extension your picture is.) When making a post you will see a little icon at the top of the text box that looks like some mountains and a sun. Click that and enter the URL and you're done!
Old 01-05-2012, 11:05 PM
  #522
Black92ryan04's Avatar
Car: 25th annv. RS
Engine: 305 TBI
Axle/Gears: LS1 3.42
Boreen,
I'd like to see your car setup/pictures. I am in the process of ordering C6 wheels and am debating wheel/tire size. I won't have to run spacers in the rear because I have a 4th gen rear end I will be installing. Let me know, thanks in advance!
Ryan
Old 01-12-2012, 08:17 PM
  #523
Mike92Firebird's Avatar
Car: 89 GTA
Engine: 5.7 TPI L98
Transmission: 700R4 w/ Stage 2 shift kit & stall
Originally Posted by sjgrimsley
Here's my 1982 Trans Am painted Viper GTS red with replica painted silver Z06 18"x9.5" and 2" adapters with Sumitomo HTRZIII tires 275/40ZR18
Sexy car you've got there....
Old 01-12-2012, 10:35 PM
  #524
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Originally Posted by DeanJ
17x8.5 /18x9.5, 2"spacer on rear, 1.7" spacer up front, I have C5 brakes on the front, thus the need for the thinner spacer. Dean
Here's an "after" pic. Same wheels painted with Duplicolor wheel paint, graphite with clear top coat.
Old 01-13-2012, 04:55 PM
  #525
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Here is mine with some zr1's
Old 01-14-2012, 09:39 PM
  #526
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
just picked up a set of C6 rims for $400 and a set of 4 2"adapters for 120. i know ill need more then 2" for the rear's but we'll see what happens probly get a two 1/4 inch spacers to run on top of the adapters but anyways heres a pic of one of my new rims, just need to get some tires n put em on the car n ill have somepics up.
Old 01-14-2012, 10:34 PM
  #527
jvaughn's Avatar
Car: 91 RS 305 TBI 5 Spd
Engine: 5.0 TBI
Transmission: 5 Spd
Axle/Gears: 323
I used 2" on the rear of my 89. Works just fine, no issues.
Attached Thumbnails Got Vette Wheels??...Post pics here...!-dsc03655.jpg   Got Vette Wheels??...Post pics here...!-253593_227057133987744_100000503767471_949200_1797484_n.jpg
Old 01-15-2012, 12:27 AM
  #528
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
wow, that came out nice!!!
is that the after pic of the car also?!?!
looking good
Old 01-15-2012, 03:16 AM
  #529
skip91's Avatar
Car: '91 RS, '64 C10 Stepside
Engine: 305 TBI, '00 5.3
Transmission: Manual, Automatic
Axle/Gears: 4th Gen with 3.42, 4.10
These have been on the local Craigslist for a couple of weeks now. $400 for the set of four. Also, here's the link if your interested: http://charleston.craigslist.org/pts/2769169234.html
Old 01-15-2012, 08:40 AM
  #530
DeanJ's Avatar
Engine: LS6
looking good
Yes it is, and
Old 01-15-2012, 10:57 AM
  #531
Ed1LE's Avatar
Engine: 5.7, 5.0
Looks great! Love the door handles btw, what are they from?
Old 01-15-2012, 11:27 AM
  #532
DeanJ's Avatar
Engine: LS6
Mid 90s Cadillac, rear doors. Lots of mid 90s GM big cars has these handles. The front door handles has the key hole in them.
Old 01-15-2012, 12:43 PM
  #533
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Originally Posted by C-Titan
Here's a few pics with the CLS rear springs, pics with the Eibachs are gonna take a while to photo-shop because they were taken at night and came out like crap... After my PHB comes in I think I may just keep the CLS springs and cut a coil to get my drop back... They ride amazingly well and feel ten times smoother (and oddly stiffer) then the Eibachs...
Pardon the filth:
I'm not a fan of how far the rear wheels stick out, bringing them in a half an inch should do the trick...
Hey C-Titan, do you think maybe we could get a side pic of this car? These pics don't really show off the wheels very well. I want to put these wheels on my car too. I'm looking at going with 18" wheels w/ the gunmetal centers to accommodate a big brake kit. The one's I was looking at appear to be quite a bit more deep dish than yours. http://www.oewheelsllc.com/Wheels_3/...els-Gunmetal_3
Old 01-15-2012, 02:51 PM
  #534
mike22115's Avatar
how wide are youre are rear's?
Old 01-15-2012, 05:24 PM
  #535
vistageek92's Avatar
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Just got my C5's installed this weekend.
17" front: 18" rear
Old 01-15-2012, 07:46 PM
  #536
ol' paddy's Avatar
Car: 1992 RS
Engine: 94 LT1
Axle/Gears: 10 Bolt 3.42
damn, your maro is clean, normally i don't like smoked lights but yours look good.
heres my rs with c4 zr1s. With the fourth gen axle they are pretty much flush with the fender lip.17x11 rear, 17x9.5 front with 2.25 inch spacer.
[IMG][/IMG]
Old 01-15-2012, 07:52 PM
  #537
[IMG][/IMG]
Thanks man, yours is looking good too.
Old 01-15-2012, 08:07 PM
  #538
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
heres a pic of mine still need the spacers though :/
Old 01-27-2012, 02:21 PM
  #539
tom camaro's Avatar
Car: 83 Camaro
Engine: LT1 SD Mode 30lb/hr
Is anyone running the LS1 brake upgrade and C6 rims?
What size spacers/adapters in the front did you use?
Old 01-27-2012, 07:54 PM
  #540
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
you will need 2in front spacers
Old 01-30-2012, 01:18 PM
  #541
tom camaro's Avatar
Car: 83 Camaro
According to everyone else on this post 2" was used for stock suspension.
The LS1 brake upgrade, due to the relocation of the rotor has moved my wheels out 3/8" (rotor hat thickness). Therefore wouldn't a 1.5" to 1 5/8" be a better fit?
Old 01-30-2012, 01:58 PM
  #542
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
That tucks tire way too far inward. Even the 2" tucks it too far in my opinion, but it maintains closer to factory scrub radius so whatever. If I were to buy again I'd pick up a 2.25" for front c6 wheels.
Old 01-31-2012, 02:55 AM
  #543
skip91's Avatar
Ed1LE,
Love the door handle mod. How do you lock and unlock your car though?
Old 01-31-2012, 11:29 PM
  #544
HI85WH1's Avatar
Car: 1992 B4C
Engine: L98 5.7 liter
Transmission: THM 700-R4
17" front: 18" rear
Nice.... spacers, tire sizes and what modifications to install?
Old 01-31-2012, 11:55 PM
  #545
dprest68's Avatar
Engine: cammed LS1
Looks nice Vistageek92. Is that Flame Red or a non-stock color? I love the wheels.
Old 02-01-2012, 03:18 PM
  #546
Z28FAST1's Avatar
Sorry guys havent been on here in a while, too busy building my downhill mt bike lol
You wont regret it.
Originally Posted by 3318RS
Wow this car is sweet!!!
thanks
Originally Posted by ghettocruiser
I think I found my next set of wheels... Probably stick with 17 x 9.5's since they seem to fit my car pretty well. Thats a good price for wheel and tire combo from OE.
J.
Its so much easier to clean these vs chrome,
Originally Posted by onetallguy19
More Pics please!
Old 02-03-2012, 07:23 AM
  #547
Ed1LE's Avatar
Engine: 5.7, 5.0
Z28FAST1, love your car. It's my wallpaper on my work computer. Do you have a build thread? Would love to see more about it!
Old 02-03-2012, 09:02 PM
  #548
HI85WH1's Avatar
Car: 1992 B4C
I set up my B4C with 19x10 rears to check for fitment.. 2.25" spacer on a rim with 8" backspacing. Seems to clear everything.. tire size would dictate how much "massaging" it would take to get them to clear on a lowered car.
Personally, I wasnt about to roll and stretch the fenders on a car with less than 10K miles.
18x8.5 up front with 6.5" backspace, also with a 2.25" spacer.. a 2" would probably be better.... depends on your front brake setup.
Old 02-03-2012, 10:47 PM
  #549
CamKid1992's Avatar
Car: 1992 Camaro
Transmission: t-5
Fitment might be ok. And setting it up just right I can see it working. But that first bump you hit will tell you everything you need to know. Either shred your tire or mangle your fender. Just be carefull. I know my tires peeled with my original shock and springs before I lowered it and put the adjustables on.
Old 02-04-2012, 12:54 PM
  #550
HI85WH1's Avatar
Car: 1992 B4C
Hence why I said I wasnt about to molest a 10K original car.
I sold the wheels to a friend who will install them on his 55 chevy truck
Quick Reply: Got Vette Wheels??...Post pics here...!
