15x10 5.5bs? Pics please!
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
I was wondering if your with 15x10..5.5bs rims can post rear shots?
From what I have read is 15x10...5.5BS is the rim to run, but when guys get 15x8s they run 4.5 (everyone says 3.5 looks like ****...but 15x10swith a 5.5 would be the exact same?)
Anyways I just ordered my moser 9inch Stock length, with 3inch long studs.
I am wondering should I just order a 15x10..6.5BS then get some spacers and just stick them in untill the tire sits nice?
Or should I just buy 5.5BS.
I am buy summit stars...so they only come 15x10 in a 4.5,5.5,6.5BS
The tires I will be running on the street is 275/50 mickeys and posibly 28x10.5 ET STREETS at the track.
Thanks Jay
Thanks Jay
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 15x10 5.5bs? Pics please!
5.5" puts the tire a bit outside the wheel well, 6.5" is best on a 10" rim, however depending on tire size, there will be some inner wheel well modification required, mainly the front area and the bumpstop.
make sure the moser rear is actually stock width, mine ended up 1/2" narrower on each side.
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
i was gonna ask the same question, but 86ta say its a 15x10 rim with the 6.5 back spacing what size tire would fit? would a 28x13.5 fit or would i be looking smaller width to a 28x11.5 or should i go smaller again to a 26x11.5
and i know about the bump stop, so what has to be done to the quarter? just roll it in a bit? or is there cutting involved?
sorry not tryin to jack your thread jay_rich, i just have a very similar question
Car: 1987 Z28
OKay Ill prob just order them with a 6.5BS then buy some extra spacers and If i need to run a spacer I will! They are only like 15bucks anyways.
If I dont need the spacers I will sell them to buddies for there skinnies haha
Jay
Car: 86 Trans Am
im pretty sure the 13.5 wont fit without a minitub.
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
