Tire Rubbing
Old Aug 3, 2009 | 05:27 AM
BowtieBoi's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Tire Rubbing
When I bought my 1989 Camaro RS it came with a set of IROC rims. The tires on the rimes are 245/50/16. I am experiencing rubbing in the front of the car.
Questions:
Will a front end alignment eliminate this problem?
Or is the tire size to wide for a Camaro RS?
Old Aug 3, 2009 | 05:45 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: Tire Rubbing
IROC wheels are NOT interchangeable front to rear and are marked on the wheels. It sounds like you have the rear wheels on the front. You can not rotate these wheels.
Old Aug 3, 2009 | 05:48 AM
BowtieBoi's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Tire Rubbing
Actually I know that much. Ive seen the stamps and the front rims are in the front and the rear rims are in the rear. I also know that my front end is out of alignment 3 degrees (up and down passenger) and half a degree (up and down driver). the passenger side is the worst. However my Toe-in / out is dead on as described in the Haynes Manual.
Old Aug 3, 2009 | 08:24 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tire Rubbing
get an alignment and see what happens.
Old Aug 3, 2009 | 09:04 AM
Stephen's Avatar
Car: 87 GTA
Re: Tire Rubbing
Where/when is it rubbing? I have no rubbing, tires are under the fenders, not setting so far out that they stick out, with 275s.
Are you lowered? If so, how much?
Old Aug 3, 2009 | 02:00 PM
BowtieBoi's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Tire Rubbing
The car as far as I know is bone stock and the previous owners did it no justice and screwed alot up on it. Ive put about 2200$ into it since I had to to keep it on the street. But as far if it is lowered It seems to be stock ride height to me. Doesnt seemed lowered If it was not much.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
MrPackstin
Oct 25, 2017 08:09 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Vincent135
Sep 28, 2015 10:50 PM
