C5 rims on my 89 Iroc?
Old Aug 20, 2009 | 04:29 PM
IndyZd's Avatar
Car: 82 IndyZd 88 IROC 84 Z28
Engine: 305 5.7 305
Transmission: auto auto auto
Axle/Gears: 2.93 G92 3.27 3.23
Hey guys,
I have a few questions I'm hoping you can help me out with.
I have a set of 2001 Corvette thin spoke wheels and am wondering if I can run them on my stock 89 disc brake equiped Iroc, or will I need to run spacers? The rims are factory thin spoke 17x8.5 and 18x9.5
The front tires are about 60% 245/40/17, the rear i've been burning off on the vette the last 2 summers so there done, size is 275/40/18.
What tire size would I run when I go to replace?
I've been reading about swapping to a gen 4 Camaro rear, and being it's widder would that be a better fit? I currently have a 2.77 rear so the 3.23 or 3.42 would be desired anyways.
Thanks Don.
Old Aug 21, 2009 | 02:21 PM
1988-305-tbi's Avatar
Re: C5 rims on my 89 Iroc?
2-2.5" up front and 2" rear. the 4th gen rear wont need spacers. stick with the tires size thats already on there
Old Aug 22, 2009 | 03:57 PM
IndyZd's Avatar
Engine: 305 5.7 305
Thanks, does anyone on here run these, I'm curious what it looks like before I start jacking up both cars and ordering spacers.
Old Aug 22, 2009 | 10:29 PM
search for "c5 rim picture" a few members have them, they should look good
Old Aug 23, 2009 | 04:25 AM
OneFast91Vert's Avatar
Car: 91 Camaro RS Vert
Engine: 305 TBI
This is how they look
Old Aug 25, 2009 | 08:21 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
I have them on my TA. I dont like the way the wheel well is now more open. Now I'm in the costly process to lower my car to make the car look right.
Old Aug 27, 2009 | 06:14 PM
LarryL's Avatar
Car: 84 TA,69 camaro,81 vet 92 vet
Engine: 400
Axle/Gears: 3:73
I have them on my 84 TA, I'm happy. I used 2"-2" spacers I'm going to try 1.5 in back, it looks like I still have 2" of clearance on the inside and I'm going to a smaller tire. I now have 245/45/17 front and 285/35/18 rear. Only thing I don't like is the steam roller look in the back. I just bought a set of goodyear eagle F1 runflats 255/35/18 for the back. The 285 measure 11.02, 255 =10.034 and 275=10.82 wide, so I figure they are about 3/8 of an inch closer to center of rim on each side. Makes for better clearance.
Old Aug 27, 2009 | 08:24 PM
so you running a shorter tire in the rear than the front????????
Old Aug 27, 2009 | 08:40 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
yes, it keeps it level. factory setup is 245/45/17 front and 275/40/18 rear. For some reason my rear has always been taller than my front since the car been new. As you know the 35 and 45 are the height since the back is 18 the 35 brings it almost level to fronts 45(17).
Old Aug 27, 2009 | 11:13 PM
Pocket's Avatar
Car: 91 Trans Am
Y2K's here too
2" on all 4 corners
1.5" will work up front but the tie rod much be clearanced some. 1.5" will not work in the rear with the 9.5" wide tires (18's) as they only leave 1/4" between the tire and LCA. A hard corner will deflect that much
Old Aug 28, 2009 | 10:45 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
Thanks for the heads up on the 1.5" spacers. I already have then but have not tried them. I noticed with the 285/35/18 tires, the tire over hag was almost 1/2 inch over rim on each side. I was hoping with the new 255/35/18 I would be able to tuck them a little tighter and I still have almost 1.5 inches of clearance.
The new quarter panels have a 1/2" larger lip on the inside wheel well opening, this is the reason why I want to tuck the wheels in more. I don't have any way to roll the edge. I know about using a bat, but don't have the extra bodys to help me do it.
Old Aug 28, 2009 | 02:02 PM
Pocket's Avatar
Car: 91 Trans Am
I run 275/40/18's on the rear and the tire is slightly wider than the rim
255's will severely stretch the sidewalls. Are you sure 35 ratio will flex that much?
Do not use a bat to roll the lip. Rent the tool and use your old wheels until its done
Old Aug 28, 2009 | 02:49 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I was told smallest size I can use is 9.5 wide tire. So now I really dont what to do.?????
I wish someone near me had one to rent. I looked all over.
Old Aug 29, 2009 | 04:36 PM
not to mention that tire is only 25" tall on an 18" wheel, very low profile... and short... lots of wheel well gap....
when you have a 26" tire on the front with 17" wheels, 2" more sidewall than the front? that really short sidewall tire would look really funny compared to the front with way more sidewall.
Old Aug 29, 2009 | 04:47 PM
HarmonyCamaro's Avatar
Car: 83 Z28 Camaro
Transmission: 5 Speed manual
i have 255,40,17 on a 17 by 9.5 inch rim the tire on the rim i can give you a picture of it if you want me to?
Old Aug 29, 2009 | 04:48 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
I have 35/18 in the back now. They fill the gap nice as far as height, just too wide. The new ones are just not as wide. As I stated before the 275 are 10.8 inches wide and hang over rim by just over 3/8 of an inch. The 255 are 10.2 inches wide and will be almost flush with the rim.
Old Aug 30, 2009 | 12:43 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
255 40 17 fronts, 275 40 18 rear Goodyear F1's. 2" Skutes all around. Finished installing Spohn's new delsphere LCA's, panhard bar and Pro kit springs. Up in the air about the LCARB's but the rear sits nice now. Next the FE.
Old Sep 1, 2009 | 01:57 AM
HOPFROG's Avatar
Car: 1985 Z28 + 1991 RS convertable
Engine: 350 TPI w/aluminum heads
Transmission: R700 w/ a shift kit
Originally Posted by IndyZd
Hey guys,
Thanks Don.
Just put C5s on my '91..I love them!!! (used 2" adapters)
Attached Thumbnails C5 rims on my 89 Iroc?-6011_1089959740837_1581787070_1438608_3412843_n.jpg
Old Sep 1, 2009 | 09:51 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
yes you will need spacers/adapters. On my 84 TA w/ stock disc brakes
the brakes are not the problem, its the back spacing of the rims. there is a sticky on how to measure to get correct back spacer. i'm using 2 INCH all around. everything clears ---but tire clearance is tight. make sure you get good adaprers and torque them down to correct amount.
Old Sep 1, 2009 | 12:44 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Axle/Gears: 95 z 3.42
here is mine with 2" front and 4th gen rear, since this pic i have lowered the rear some more with the hose mod. now it sits good. Tires are 245/45/17 and 275/40/18 and fit just fine.
Old Sep 1, 2009 | 01:21 PM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
They look great. I love the way they looked polished. I think polishing may be my winter project.
Old Sep 1, 2009 | 07:52 PM
bschafert's Avatar
Car: 91 RS
Transmission: Soon to be T56
Axle/Gears: 3:23
I know the better option is to run the fourth gen rear instead of spacers but is there anyway around running spacers on the front? like a knuckle kit?
Old Sep 1, 2009 | 08:02 PM
bschafert's Avatar
Car: 91 RS
Axle/Gears: 3:23
Old Sep 1, 2009 | 08:04 PM
Pocket's Avatar
Car: 91 Trans Am
Custom spindles
Old Sep 2, 2009 | 10:40 AM
LarryL's Avatar
Engine: 400
Axle/Gears: 3:73
not that I know of. But that does not mean that there is nothing. I would do some heavy web searching and reading,you never know what you will find.
Old Sep 8, 2009 | 07:09 PM
bschafert's Avatar
Car: 91 RS
Axle/Gears: 3:23
i just got my fourth gen rear in and decided to throw up my c5s to see what they look like, i have the same ones as larry but chrome. the original owner had them chromed. my rear is out of like a 93Z and my wheels wont go over the hub easily. i dont want to force them but idk if i have to bore out the wheel with a dremel? anyone else have this problem?
Old Sep 8, 2009 | 07:17 PM
Pocket's Avatar
Car: 91 Trans Am
No, GM use the standard 5 on 4.75" for all 3rd and 4th gens. Corvette wheels are a direct swap
Old Sep 8, 2009 | 07:25 PM
bschafert's Avatar
Car: 91 RS
Axle/Gears: 3:23
yea i know that but i mean like the center hub that they rest on. its really tight
Old Sep 9, 2009 | 09:43 PM
bschafert's Avatar
Car: 91 RS
Axle/Gears: 3:23
another thing i encountered is my studs seem a little short, i have a 93-97 Z rear anyone else have this problem?
Djmathis123
Sep 29, 2015 01:36 AM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
g.l.mos
Aug 22, 2015 12:02 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
