Question about 15x8 wheels
Old Nov 2, 2009 | 11:51 PM
gill9228's Avatar
Car: 1989 Camaro Iroc
Engine: 5.0 TPI
Transmission: 700 R4
Hey guys, just trying to figure out if a set of 15x8 wheels with 5.50 in backspacing will fit on a 89 camaro. It has a stock 10 bolt with drum brakes. I am also planing on putting 275 60 15 tires on these wheels. The car will be lowered 2 inches in the rear also.. Will this combination fit.
Thanks,
Paul
Old Nov 3, 2009 | 05:20 PM
Guest
Guest
Posts: n/a
Re: Question about 15x8 wheels
Not on the front it wont. On the rear, they'd be awfully far under. Look for a 4.5" backspace, aka a zero offset. That's excellent for all 4 corners. Then think more like a set of 245/60R15s.
Old Nov 3, 2009 | 06:50 PM
gill9228's Avatar
Engine: 5.0 TPI
well, like i said, I want these just for the rear. Im using 15x4's up front. Anyway, I want to use a wheel that will go far into the wheel well. I dont want them to stick out at all. I figured a 5.5 in offset would be best for that. I also heard that 275 tires will fit on an 8 inch wheel.
Old Nov 3, 2009 | 09:08 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
they will fit. i have 15*9 with a 5.5 bs wiht a 275/60/15 mt et street.
Old Nov 3, 2009 | 10:13 PM
gill9228's Avatar
Engine: 5.0 TPI
Thank you for the reply. I am going to order a set of these now. How do you feel about lowering the rear 2 inches. Will the tires rub?
Old Nov 4, 2009 | 07:54 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
no they shouldn't. i've lowered mine another 3/4" last night and still have more room to go. Make sure your rear is centered laterally correct.
Old Dec 2, 2009 | 10:39 AM
84_Maro's Avatar
Car: 84 Berlinetta
would 15x7's i the front look good with 15x8's in the back, and is it possible i go with a 0 offset? and what kind of tire size should i be using for both wheels??
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
