Factory Wheel Spacer
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
Anybody know what the size of a factory wheel spacer is that was used on the rear?
I heard 3/8", which is about what I need to bring my wheels back out, but I'm not certain that's what it is.
Thanks for the help fellas,
-Levi
-Levi
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Factory Wheel Spacer
This from the 10-bolt FAQ:
The spacer was apparently used on 16" wheels when GM switched from aluminum to iron drums, which created a .187 size difference. The spacer, however, seems to be hit or miss and essentially unnecessary. Even some disc brake cars received them [mine did].
JamesC
JamesC
Engine: L98/454/M20
Alright, thanks guys, disappointing, but i'll figure it out.
Any idea where I could find, say, a 10-15mm spacer that has the dual lug nut setup like the thicker 1" and up spacers, or are they even necessary for a spacer that thin? If I was go with say a 15mm spacer, would I have to change to longer studs for my front rotors, or could I just use the ones that are on there?
Thanks,
-Levi
Thanks,
-Levi
Those factory spacers were .187 thick and were usless. They were installed so the engineering drawing numbers would be correct and not show that -.187 dim error.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i bought some 91-92 wheels out of the local paper at a deal years ago.
loaded everything up and was going to leave and the guy was chasing me down waving the spacers.
"youll need these spacers or they wont fit."
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
I've always wondered about those lil discs that came on my rear... Never knew they actually came from the factory like that... haha
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
