wheel studs
Old Feb 3, 2010 | 08:04 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Engine: 350 worked, 305
Transmission: 5 speed zbar setup. auto
Axle/Gears: 3:73 gears. stock
wheel studs
Ok so im putting a 3:73 posi rear in my 87 iroc from my 83 parts car. So i want to put in longer wheel studs, dont want it to be thicker, i want it to fit in stock axles but be like 3inches long or something. What studs do i need and how do i take my axles out. All help is appreciated.
Old Feb 3, 2010 | 08:06 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Re: wheel studs
btw its a drum rear
Old Feb 3, 2010 | 08:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: wheel studs
To provide an idea, OE studs are 12mm x 1.5 right hand thread. The following link will detail axle removal:
https://www.thirdgen.org/forums/tran...ing-axles.html
You might consider taking a peek at the 10-Bolt FAQ as well.
JamesC
Old Feb 7, 2010 | 04:08 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Re: wheel studs
bump. thanks man
Old Feb 9, 2010 | 12:48 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
Re: wheel studs
http://www.summitracing.com/parts/ARP-100-7713/
guy i bought my welds from used these and its wat i plan on running so i can bolt my welds up.
Old Feb 12, 2010 | 11:30 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: wheel studs
im gonna try the moser 8255
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
