Wheel fitment question...
Car: 1988 Pontiac Firebird Trans AM GTA
Engine: Tune-port Injected 6.3L
Transmission: Borg-Warner T56 six-speed
Axle/Gears: Borg/Warner 9-bolt with 3.70:1
In an effort to be different I'm looking at a set of 2009 G8 wheels for my GTA if they'll fit. The dimensions of the wheels are going to be 18x8 (not a problem fitting in the wheel wells), but I have a question about the bolt pattern and offset. The factory bolt patter for the wheels is 5x120 with a 48mm offset and 14x1.5 lugs. Is 5x120 the same as 5x4.75? Will these bolt up, given the correct wheel adapter? If so, what size wheel adapter would I need to mount them on my 1988 GTA? Appreciate the assistance.
These are the wheels (it won't let me right-click) --> CLICK ME!
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Re: Wheel fitment question...
4.75 is 120.65mm but if i remember right that means its only .65mm on each lug 5.120 are bmw specs and there is a few people on here running them so that shouldnt be a problem not sure about the offset and lug size though.
Good luck though post some pics up when you get them on
Car: 87 GTA
Close enough to a Corvette GS ZR1 style wheel (17x9.5/50mm) which uses a 2" adapter for 3rd gen fitment.
Some of the BMW wheel guys have had to use a rat tail file to slightly clearance the wheel lug holes, but that is nothing to be concerned about.
I have no info, but I would assume the GTOs use a conical lug nut as well, so that shouldn't be a problem with your current lug nuts.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
my only concern would be the lug nit size, since the wheels are setup for the larger 14mm stubs, i wonder how well the 3rd gen 12mm stud and conical nut would seat? i wonder if there would be enough meat on the opening for the smaller nut to grab onto?
Car: 87 GTA
If it was the opposite, 14mm lugs fitting into a 12mm hole, I could see an issue. But since they are smaller, I say they'll fit fine.
With conical seats, they should center up perfectly fine. I don't thin k there would be a lack of seat material to match up good.
Anybody have a GTO, or a friend/relative with one, who's willing to test this out?
Thanks for the info.
Chad Speier
Sep 24, 2015 12:32 PM
punkmaster98
Sep 8, 2015 09:45 PM
