quick wheel spacer question
Old Feb 22, 2010 | 01:27 PM
yamaha6611's Avatar
hey guys i for the hell of it bought a set of wheel spacers for my gta, i know they tear up wheel bearings and whatnot but im not too concerned about that, what i am concerned about is...
the amount of stud left for the wheel after i put them on... its pretty minimal, but the lug nuts spin about 4 times a piece until tight, you think this is enough room??? or am i running the chance of ripping the wheel off?? thanks
matt
Old Feb 22, 2010 | 08:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: quick wheel spacer question
you mean a slip on spacer?
you want at least 1.5 times the width of the stud of thread engagement, thats 18mm, about 3/4". You dont seem to have nearly that much, so you have to get longer studs installed if you plan to use those spacers. They will shear if you leave them the way they are.
Old Feb 22, 2010 | 10:45 PM
yamaha6611's Avatar
yea thats what i figured theyre 5/16's aluminum slip on spacers, just wanted to fill in the wheel well on the TA a little more, they look alright just... need those longer studs...
Old Feb 22, 2010 | 11:33 PM
Stephen's Avatar
Car: 87 GTA
Sound like the same size as the stock 3rd gen, aluminum drum equipped early 3rd gens came with. Perfectly safe, with stock length studs.
I had some OEM ones...Put them on just because I had them, when trying to make room for my 315s & once I got the room I needed, I was too lzy to pull the wheels off just to take the spacer out. So they are still on the car, under my 11" wheels & 315s.
Old Feb 23, 2010 | 02:13 AM
yamaha6611's Avatar
i have all wheel disks... its a gta... not sure if that is different from the camaros or whatnot, but i dont have a ton of stud left.. imean sticking out from the spacer.. none, but i have those dumb special lugs for cars with wheels with little lug holes, they work fine and tightened up fine, but i bet its only about 1/4in threaded on the stud.. what do you think?
Old Feb 23, 2010 | 09:08 AM
Stephen's Avatar
Car: 87 GTA
If that is all you have, I would look for longer wheel studs. Maybe ours are different for some reason (GTA, all discs for me too).
Old Feb 24, 2010 | 09:39 AM
yamaha6611's Avatar
i think pics and vids should do the justice!
lol lemme get on that.
Amillionoh7
May 24, 2020 08:01 AM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
