messed up front alignment?? wtf
Old Apr 18, 2010 | 01:52 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
i just drove bout a hundred miles to my girlfriends house, and it seemed to want to go to the right, and when i got here, it appears my front passenger side tire seems weird. almost like the bottom of the tire looks in too far( like when you take it off the jack stands)
I got a new spohn steering kit last year and got the car aligned at the same time.
any one else have this?
Old Apr 18, 2010 | 04:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: messed up front alignment?? wtf
maybe the strut mount is loose and it moved?
Old Apr 18, 2010 | 04:29 PM
Stephen's Avatar
Car: 87 GTA
I would check for loose nuts/bolts, that they failed to fully tighten after the alignment was done. Both on the strut tower & everywhere else.
Old Apr 18, 2010 | 06:14 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
i checked, and eveything seems tight.
Could it be that my tie rod is not adjusted right? or tightened to far?
its killin the outer tread of my new Falken tire=[
Old Apr 18, 2010 | 06:20 PM
Stephen's Avatar
Car: 87 GTA
How long ago was it done & how many miles have you been driving it like that?
I've gone around the block, pulled back in...."Its not right...You need to realign it again."
Old Apr 18, 2010 | 06:35 PM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
well i got it done last september, and stored it in november. i thought i noticed it alittle bit but it does good in town.
on the highway is when its bad, like 65 and up.
but i got it out like a month ago and it just seems to have gotten alot worse
Old Apr 19, 2010 | 06:29 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
regardless, shes goin to the alignment sho today.
btw, nice T/A Stephen
Amillionoh7
May 24, 2020 08:01 AM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
383backinblack
Aug 15, 2015 06:36 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
