18x9.5 up front? nop
Old May 10, 2010 | 06:30 PM
canadiangta's Avatar
Im going bonkers trying to find a 1 peice wheel. Settin up for road, want to do 18x9.5 all around, 275/35-18 JUST LIKE PROJECT SNOWBALL in gm high tech mag. Boss 338 almost fit, some dealers say ya, no problem, some say nope, hub wont clear. I need 9.5 wide to get the tires i need.
Boss 338 18x9.5
5"BS -4mm offset
275/35-18
same diameter, radius, and circumfrence as factory 245/50-16
Any help???
Old May 10, 2010 | 08:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 18x9.5 up front? nop
ccw?
Old May 10, 2010 | 08:45 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
I have them up front...AND I run coilovers. Mine are an Italian wheel that is no longer made. CCW, Fikse, HRE, and all the good wheels will make some to fit. An 18x9.5 with a stock C5 Z06 offset will fit with a spacer (same spacer needed to fit 4th gen wheels).
Old May 10, 2010 | 09:10 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
a -4mm offset will definitely be too far out away from the car. Ideally, a +19mm offset should fit best.
Old May 11, 2010 | 12:59 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
A 9" with a 5.5" BS wheel in the front should work fine with the 275/35-18.
Old May 11, 2010 | 07:55 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
a 275/35 really belongs on a 10.0-10.5" rim. 9.5 is about the minimum. 275/40s on 9s works because of the taller sidewall height, but doesn't work well.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
