Will 1996 corvette wheels fit?
Old Jun 16, 2010 | 12:35 PM
yo soy el warg's Avatar
I'm going to look at a set of directional 1996 corvette wheels for sale. I want to put them on my 1992 Camaro. The owner doesn't know if they are 17" by 8 1/2", or 17" by 9 1/2", or 17" by 11", will any of these fit my Camaro? The offset is what concerns me. Thanks
Old Jun 16, 2010 | 01:01 PM
Stephen's Avatar
Car: 87 GTA
Re: Will 1996 corvette wheels fit?
Yes, with the right sized adapters.
Do a here on TGO & you'll find the answer a million times, plus a chart showing specific wheels & the adapters needed for each one.
Or just read the Sticky at the top of this Forum.
Old Jun 16, 2010 | 09:23 PM
396l35's Avatar
Car: 3 1969's and original owner 1987
They sure do fit....
Old Jun 16, 2010 | 11:36 PM
What size spacers did you use? Also, what size were the wheels and tires? One last thing, do you have any problem with them rubbing when you corner hard?
Old Jun 17, 2010 | 01:12 PM
396l35's Avatar
I went with a 2" spacer in the rear and a 2.25" in the front. Wheels are 17x11 with a 7.8" backspace and the fronts are 17x9.5 with a 7.1" backspace. The rear tires are 315/35R17 and the fronts are 275/40ZR17. The front rubs a little in the rear on a hard turn so if you go with a smaller front tire it should get by with no rubbing.
Old Jun 17, 2010 | 03:27 PM
The wheels I looked at were 17x11 with a 7.8" backspace on the rear and the fronts are 17x9.5 with a backspace of 7.1". The rear tires are 275/40R17 and the front tires are 245/40R17 so 2" spacers in the rear and 2.25 on the front will work with no problems. Thanks for the information
Old Jun 17, 2010 | 03:54 PM
396l35's Avatar
Im glad I could help...
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
kah992
Aug 19, 2015 02:55 PM
milk
Aug 10, 2015 06:26 PM
