GTA wheel question
Old Jun 18, 2010 | 12:08 PM
myslomaro's Avatar
GTA wheel question
I just picked up a set of gta wheels for my formula and i noticed the wheel lips on 2 of the rims are wider than the other two. my question is how do i determine which rims go on the front and which go on the back as the offset appears to be different and im worried about rubbing my fenders.
Any help would be appreciated
Old Jun 18, 2010 | 12:47 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Re: GTA wheel question
Check this out. https://www.thirdgen.org/16-inch-wheel-offset and
https://www.thirdgen.org/forums/whee...er-wanted.html Show be at the top of the forum.
I don't think that the rims lip wouldnt make much different on the GTA. Only the offset of the rims.
If the lip is wider it would go in the rear.
Old Jun 18, 2010 | 01:03 PM
Rob's 92 gta's Avatar
Car: 92 firebird gta
Engine: L98 with minor mods.
I have a 92 gta and the rims with the larger lip goes on the front to offset the wheels out more for handling purposes. It also keeps your tires from rubbing the car when the wheels are turned completely.
Old Jun 18, 2010 | 01:09 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
If they are GTA crosslace wheels they should all be 16x8. But there should be 2 wheels that appear wider, than the other two. These wider wheels are supposed to go on the front of the car. If you put the skinnier looking ones in the front they will rub.
Old Jun 18, 2010 | 01:11 PM
Stephen's Avatar
Car: 87 GTA
Wrong. As said below....The wider lip goes up front. And the lips are different widths, because of the different offset.
Just flip the wheels over & remove all doubt. You will find that they are marked FRONT & REAR, which removes all doubt.
Old Jun 19, 2010 | 05:45 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
Wrong. It would require a little work with a grinder up front.
Old Jun 19, 2010 | 07:47 PM
Okay, my mistake so I had it the other way around.
The reason is because I was looking at the outer rim wider lip would be in the rear. Thanks for clearing that up.
breynolds thanks, but don't need to repeat. It already be said by the others.
Old Jun 19, 2010 | 08:41 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
...and I didn't read the whole thread before responding. Sorry.
Old Jun 24, 2010 | 06:52 PM
Docfirebrd's Avatar
Engine: 350/5.7 TPI
Axle/Gears: Unkown at this time
Rob's 92 and Bigbad are correct. The shallower offset (wider outside rim area) goes on the fornt to allow clearance for the strut mount. The deeper offset (narrower outside rim area) goes on the rear. PO of my car had put them on my GTA wrong and had added a 1/8 inch wheel spacer on the front to get the clearance back.
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
