What's the widest tire?
Old Jun 19, 2010 | 05:51 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Transmission: 97GM BW T-56
Axle/Gears: 9", Moser 31 Splines 3.73s Trac Loc
you can fit on a stock rearend without rubbing or having them stick out all to be hell?
Old Jun 19, 2010 | 05:55 PM
Stephen's Avatar
Car: 87 GTA
Re: What's the widest tire?
I've got 315s on my stock rear end. I'm not tubbed, but I did have to do some trimming to the inside of the fenderwell.
The BFG 295/50s on stock 16" wheels fit just fine too.
But you'll hafta be a little more specific on what wheels you are running or want to run.
Old Jun 19, 2010 | 06:56 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
I've got the stock 16" crosslace wheels on it now. I have no idea what the back spacing is. I'm going to be getting a set of Pro Stars for the track though. Kinda wanting to know how big a tire I can fit on both. 11.5 x 28? I had BFG G Force Sports on my GTA and had 255s on the stock crosslace wheels. Fit just fine. Wanna know if I can go bigger.
Old Jun 19, 2010 | 07:27 PM
Stephen's Avatar
Car: 87 GTA
Te BFG 295/50s will fit your crosslaces, but they are the greatest as far as traction though. good for the street, but they are H-rated tires. Not real soft but great for a highway tire.
Your rear crosslaces are 16m positive offset, or 4.9" backspacing. Call it 5" for ease. You can go 6" easily & 6.5" isn't real hard, but you'd wanna make sure the rear axle is centered. Mine was off by almost a full inch with the stock PHB, so I got me an adjustable one to center it up good, to fit the 315s under my fenders.
Old Jun 19, 2010 | 08:43 PM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
Ahh...good tip. So what size exactly are you running under yours then. What combo as far as wheel and axle.
Old Jun 19, 2010 | 08:50 PM
Stephen's Avatar
Car: 87 GTA
275/40RZ17s on 17" x 9"/5" bs front.....
315/40ZR17s on 17" x 11"/7"bs rear.....
But the rear required tubular LCAs with the offset bushings/adjustable panhard bar/inner sheetmetal cutting/e-brake bracket cutting.....It wasn't real easy, but well worth it to keep them completely under the fenders!
Old Jun 20, 2010 | 09:39 AM
breynolds's Avatar
Car: 91 Firechicken
Engine: 355ci SBC
We'll be talking soon on your setup. That's pretty much what I'm wanting.
Old Jun 20, 2010 | 09:48 AM
Stephen's Avatar
Car: 87 GTA
https://www.thirdgen.org/forums/whee...els-315-a.html
Old Jun 20, 2010 | 10:43 AM
Badass355ciz28's Avatar
Car: 1983 CHEVROLET CAMARO Z28
Engine: Forged 355 with a GT45 turbo
Transmission: TKO 600
Axle/Gears: built 4th gen rear with 3.27s
ahh my old wheels def look good painted like that stephen
Old Jun 20, 2010 | 10:52 AM
Stephen's Avatar
Car: 87 GTA
I had them powdercoated to match my fronts that I already had, after I had them widened from 9" to 11".
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
