C6 Wheels question
Old Jun 24, 2010 | 10:04 PM
91RScamaro355's Avatar
C6 Wheels question
I have a set of 17x9.5 C6 wheels going onto my 91 Camaro. What size spacers do I need on the front and rear for them to work?
Old Jun 25, 2010 | 04:59 PM
hurd85ta's Avatar
Car: 85 trans am
Engine: 305 tpi
Transmission: 5 speed
Re: C6 Wheels question
Im running 17x8.5 wheels in the front 18x9.5 rear all on 2" ADAPTERS. Theres no such thing as a 2" spacer btw. The corvette c6 wheel has a 56mm offset this is why an adapter is needed. If you have a stock thirdgen rear end you need 2" adapters for the rear aswell. A lot of guys run a 4th gen rear end because the axel has +2" on each side, therefor they dont need to run spacers in the rear. So assuming you have have a stock rear end you will need spacers on all corners.
Hopefully this was helpful.
Old Jun 26, 2010 | 12:33 AM
Ok. Thanks for the help. I appreciate it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
