Mt et streets
Old Jul 20, 2010 | 08:45 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Mt et streets
I am looking at getting a set of mt et streets for the track. I have 16X8 inch rims in back. Would a 26X11.5X16 fit on the wheel and then would it fit in the wheel well without any banging?? On mickey thompson's website they say the 11.5 should not be on anything that is smaller than 8.7 inch wide wheel
Old Jul 20, 2010 | 08:47 AM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: Mt et streets
https://www.thirdgen.org/forums/orga...licks-fit.html
they fit bro, i wouldnt steer ya wrong.
some have had to clearance, some dont, its kinda a hit or miss deal it seems, but those who have needed to clearance, its minimal right by the LCA mount.
Old Jul 20, 2010 | 08:50 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: Mt et streets
just didn't want to buy somthing and see that I have to use a hammer to make them fit
Old Jul 20, 2010 | 08:53 AM
On Probation
Re: Mt et streets
LOL, i hear ya man..
i refuse to take a hammer to my car, these, aside from 255 mickey drag radials, are about the only options that work for these cars, and my 255 mickey dr's didnt 60ft very well being my car is a stickshift
Old Jul 20, 2010 | 07:37 PM
TMFK's Avatar
Car: 85 Z28
Engine: ZZ-3,Mini-Ram, Holley EFI
Transmission: 700-R4
Axle/Gears: Hawks 8.8
Re: Mt et streets
I run 295/50-16 (28x11.5-16) et street radial II's
http://www.mickeythompsontires.com/s.../50R16&type=SS
Had to remove the bump stops and some of the sheet metal above the bumps. Also had to clearance (hit with hammer) inside the wheel well. The mods were very minor and took less than an hour. I'm running iroc 16x8's.
Old Jul 22, 2010 | 10:42 AM
otecnick88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350 .060 over carbed
Transmission: TH-700R4 w/2800 stall
Axle/Gears: 9 bolt w/3.27s till it breaks
Re: Mt et streets
Not tryin to hijack here
now I'm runnin the same tires as you and they rum like crazy on my fenders even tho I trimmed them and bent them, are you running stock springs? Or have any other suspension mod in the back there, pm me some pictures if you have them and don't mind
Old Aug 18, 2010 | 01:52 PM
mcbchild's Avatar
Car: 1984 Firebird SE
Engine: 388 sbc, Brodix Track 1s
Transmission: turbo 350 transmission
Axle/Gears: 4.10 gears
Re: Mt et streets
I am running MT ET streets 27x10.5x16 on my rear gta crosslace wheels and never had any rub what's so ever and I run the eibach rear drag launch springs which is about the stock height, but compresses more for the rear squat for traction.
cheesehomer
Dec 31, 2015 08:48 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Doobie52
Sep 11, 2015 06:19 PM
