Pretty Simple Tire Question
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I have a 90 Camaro RS. She now was 18" wheels with 245/45/18 on it. There is a little bit of rubbing what tire size should i go with on the front to eliminate the problem i dont really want to make the tire less wide. also whats a good size for the back without making them look to big id like to go wide
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Pretty Simple Tire Question
245/45-18 is too tall. A 245/40-18 would be the same height as a stock 245/50-16. Ditto for a 275/35-18 but make sure the wheel is wide enough.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
you can, but they would need a wheels thats at least 9" or wider, what do you have now?
