Which way do these spacers go on?
Old Aug 21, 2010 | 05:18 PM
92-Formula's Avatar
Here's a stupid question for you all. Im doing an LS1 brake conversion on a 92 formula. In order to get the brakes to fit with GTA wheels I needed the stock GM .3" rear drum spacers. I just recently got them and just wanted to verify that the side that says "OUTBOARD ONLY" is the RIM side? So im assuming the really rusty side is the "hub/drum brake" side? Does it even matter?
Im also considering sanding them down just a little bit to get rid of the rust and then painting them with some anti-rust stuff. Is that even worth my time? Thanks.
Old Aug 21, 2010 | 05:40 PM
Stephen's Avatar
Car: 87 GTA
Re: Which way do these spacers go on?
You are correct. Outboard = wheel
Old Aug 21, 2010 | 05:49 PM
92-Formula's Avatar
Old Aug 21, 2010 | 07:37 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I don tthink it wouldnt hurt to clean em up some
Old Aug 21, 2010 | 08:36 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Yes. A VERY thin coat of wheel bearing grease on either side and the hub bore, when installing, wouldn't hurt, either.
Old Aug 22, 2010 | 02:13 AM
92-Formula's Avatar
Good call - thanks again for the advice guys.
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
