Tire Size ????
Old Aug 30, 2010 | 07:13 PM
200trueblue's Avatar
Tire Size ????
Newbie here..
Stock tires on a 86 Z28 that i'm looking at is 215-65-15 and they are
dried and cracked and i was wondering if a set of 235 70 15 would fit
without any problems like striking the fenders etc..in order to drive it home 300 miles ?
TB
Old Aug 30, 2010 | 07:27 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Tire Size ????
those are truck tires, 29 inch tall. they "may" barely work on the rear, but dont count in it, not a chance on the front
Old Aug 31, 2010 | 10:51 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Tire Size ????
They're 28". If the car isn't lowered, and if you don't turn tight, ( even if it means making 12 point turns instead of 3-point ) Then it should work. I've done 215/75R15s, and they're 27.7".
Your speedometer should show 51 when you're really doing 55.
Old Aug 31, 2010 | 07:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Tire Size ????
you are right, i must have punched in a wrong number on the chart, came up with 28.9" diameter
28 is still really tight on the front, you will really have be be careful turning.
Old Sep 11, 2010 | 06:00 PM
stackofire's Avatar
Car: 1991 Camaro Z/28 305
Re: Tire Size ????
Is there anyone who can tell me whether I will be able to fit 295/50 R15 on the back of '91 Z28 without any modification? Or are they gonna be too wide?
If it's not possible I will go for 275/60 R15...
Good choice? Bad?
Old Sep 11, 2010 | 06:11 PM
Stephen's Avatar
Car: 87 GTA
Re: Tire Size ????
Good choice? Bad?
In the rear? Depends on the backspacing of your wheels. Yes, if your bs is good. No if it isn't.
Old Sep 11, 2010 | 07:09 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: Tire Size ????
What is the biggest i could fit on stock crosslace rims in the rear and the widest in the front
Old Sep 11, 2010 | 08:05 PM
Stephen's Avatar
Car: 87 GTA
Re: Tire Size ????
15" or 16" crosslaces?
The 16" wheels are 8" wide and the BFG 295/50R16 will fit just fine in the rear (been there, done that myself). And for a street 16" tire, 255 is the biggest they make except the 295, which will not fit up front.
IIRC, the 15" crosslaces are only 7", so I (personally) wouldn't go more than 265/275, but those aren't real common widths & the aspect ratio has to be kept in check, not to get too large in overall diameter.
275s will fit up front, but you really have to get the backspacing of the wheel just right, which would be hard on a 15" wheel clearing the strut & spindle.
Old Sep 11, 2010 | 08:14 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Tire Size ????
The 295 rear and 255 combo I think would be perfect. Its what I plan on running on my IROC wheels for the street. Just keep in mind that the 295 tire is taller than stock so you will be going faster than what your speedometer says.
Old Sep 11, 2010 | 10:17 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: Tire Size ????
I have the 16x8, Well could the speedo gearing be accounted for, if not what is the largest tire that wont affect the speedo gear. It is a mechanical speedo. Also i dont wanna use wheel spacers.
Old Sep 11, 2010 | 10:36 PM
built91Z28's Avatar
Re: Tire Size ????
255/50/16 is stock height. You could get different gears to account for the tire.
Old Sep 12, 2010 | 03:20 AM
BigWhiteGTP's Avatar
Car: 1994 Trans Am
Re: Tire Size ????
Look for a 245/50r15 or something. If your spending the money, make it look good at least. You don't want tall skinny tires on a Z28 do you?
Old Sep 12, 2010 | 06:22 AM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: Tire Size ????
i got that but i dont understand how a wider tire would affect the gearing i thought if it was taller that the height would affect the gearing
Old Sep 12, 2010 | 08:11 AM
Stephen's Avatar
Car: 87 GTA
Re: Tire Size ????
Just wider won't. But 50% of 295 = taller overall than 50% of 245. (295/50 & 245/50)
Old Sep 12, 2010 | 10:16 AM
built91Z28's Avatar
Re: Tire Size ????
The first number in a tire size is the width in milimeters. So a 295 is about 295 milimeters wide. The second number is the aspect ratio. What that means is that whatever the number is, say 50 for this tire, the tire sidewall is 50% of the width. So a 295/50's sidewall is 50% of 295 milimeters tall. Thats why its taller than a tire that has a sidewall that is 50% the height of 245 milimeters.
Old Sep 12, 2010 | 04:03 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: Tire Size ????
oooooo will the difference be noticable or if im doing 50 will it say 52.
Old Sep 12, 2010 | 06:02 PM
built91Z28's Avatar
Re: Tire Size ????
Here is a calculator you can play with. Just put in what rear gear you have, the ratio of whatever gear you will be in for the trans, and your tire size and it will give you rpm.
http://www.fbody.com/calc.htm
Old Sep 13, 2010 | 06:03 AM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: Tire Size ????
It is a differnece of about 100 rpms, which is not significant, i jsut cant find a tire that they make in 295/50/16 and in 255/50/16.
Old Sep 13, 2010 | 08:22 AM
Stephen's Avatar
Car: 87 GTA
Re: Tire Size ????
BFG has the ONLY 295/50R16 that I know of.
Old Sep 13, 2010 | 08:38 AM
built91Z28's Avatar
Re: Tire Size ????
Yea the only 295's I've found for 16's are the BFG's and Mickey Thompson drag radials.
Old Sep 13, 2010 | 03:46 PM
MassD's Avatar
Car: 1984 Trans Am
Axle/Gears: 3:73
Re: Tire Size ????
yea and it is my dd so the drag radials are no good for rain, and the BFGs dont come in a 255
Old Sep 15, 2010 | 08:19 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Tire Size ????
235/60R15 firestone makes a good tire
Old Sep 23, 2010 | 02:51 PM
stackofire's Avatar
Re: Tire Size ????
Finally fitted new wheels and tyres.
So I can now confirm that the 275/60 R15 will fit at the back of 1991 Z28 with stock suspension but they will rub on the wheel arch on every little bump on the road.
That's how they look:
21092010260.jpg?t=1285271398
21092010255.jpg?t=1285271423
BTW the front ones are 225/60 R15
Wheels are Cragar S330 15x7 front, 15x8 rear.
I had to cut a bit of the wheel arch lip to be able to drive... I'm gonna to put adjustable shocks at the rear as well to minimise the bounce.
Old Sep 24, 2010 | 05:57 AM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
Re: Tire Size ????
Here's a handy calculator that i have been using alot lately:
http://www.miata.net/garage/tirecalc.html
It doesn't tell you tire clearance at all, but it will help you keep your profile close to Original when you're using different size wheels and tires. Really handy tool.
Old Sep 24, 2010 | 02:42 PM
stackofire's Avatar
Re: Tire Size ????
Hey, thanks.
I used it before I bought the tires but never took account of car bouncing up and down on uneven surface. Stiffer shocks should sort that out tho.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
