bigger wheels in the rear
Old Sep 11, 2010 | 07:33 PM
StripedCam20's Avatar
Car: 1991 Chevy Camaro RS
Hey guys, have a 91 camaro with aftermarket 17 inch irocs on it, i was thinking of getting two 18 inch irocs and putting them in the back just wondering what you guys think...
thanks
Old Sep 13, 2010 | 11:28 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: bigger wheels in the rear
People do it all the time. The rim size is really the question though. Its what size tire your going to put on it.
Old Sep 13, 2010 | 12:11 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
I agree that the tire size matters. 18's out back and 17's up front looks fine if the rear wheels and tires are wider than the fronts. If they are the same size, just taller, then it looks kinda goofy.
Old Sep 13, 2010 | 02:14 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
Im not the biggest fan of it, but yes the tire size on the rims in back will really determine the overall look. Do what you like.
Old Sep 14, 2010 | 10:12 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I used to run the staggered IROC's (18/20). They looked good....but it's very true that it looked kind of funny because the rear 20's were only 8 inches wide...same as the 18's up front. Now I'm running 19X8 up front and 20X10 in the back...which looks much better.
the old IROC's:
Old Sep 30, 2010 | 02:00 AM
JT-5.7TPI-IROCZ's Avatar
Car: 1989 iroc z
Axle/Gears: 9bolt/3.45
Sickness - thats exactly what i want to do, what size tires are you running and is it stock height??
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
kah992
Aug 19, 2015 02:55 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
