Help with 91 Ta wheel fitment...
Car: Trans Am GTA
Hi guys Ive got a 91 Trans am and I was wondering if I could put some cragar 16x8's on and If so does anybody know the correct bolt pattern...heres a link that lists the bolt patterns for the 16x8's...Thanks guys!
http://www.performanceplustire.com/b...30-super-spoke
Car: 98 camaro ss, 98 grand cherokee 5sp
Engine: 5.7 ls1, 4.0 sixxer
Transmission: T56, ax15 swapped
Axle/Gears: 3.42, 3.73
Re: Help with 91 Ta wheel fitment...
5 by 4.75" ( 5 by 120.7mm?)
Car: Trans Am GTA
Haha not sure what that completely means...as it is not listed on the link...As you can tell I know nothing about tires and wheels so...I just wondered if the 16x8s would fit and if so what bolt pattern I would need.
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
that means those rims are not available in 16x8 for our bolt pattern, they are available in 15x8 but why those are horrible and for the price could definitely do better.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The bolt pattern you need for the car is 5 lug, on a 4.75" spacing. The stock setup used a wheels with zero offset, or 4.5" of backspacing on the front, and 16mm offset, or about 5.125" of backpascing on the rear.
those wheels you listed are not available for this application.
what wheels do you have now? pics?
Car: 1991 Camaro Z/28 305
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
My opinion on that is a bit different
