View Poll Results: Which WLT to buy?
BF goodrich radial T/A
20
41.67%
Firestone Indy 500
28
58.33%
Voters: 48. You may not vote on this poll
white letter poll.. Radial T/A or Indy 500?
Car: 1982 Trans am
Engine: 383
Transmission: AGE M22Z
Axle/Gears: Moser 9" 3.70 detroit locker
Car: 1989 Forumla 350 WS6
Engine: 5.7 TPI:Bosch III's 22#'s
Transmission: 700-R4
Axle/Gears: BW 9 Bolt Posi- 3:27
Re: white letter poll.. Radial T/A or Indy 500?
17 for Firestone and 12 for ta's. Is the story.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 1984 Trans Am WS6
Engine: LG4
Axle/Gears: 3.23 LSD
Just another thought... if you're bent on those two then I think this thread pretty much covered it. The Firehawks are the more modern of the two, but the Radial T/A's are classic, and that goes for both looks and performance on both of them. But if you're still not sure, they also sell paint markers that make any tire look as if it has white (or yellow) lettering : http://www.amazon.com/Duplicolor-Tir.../dp/B000FNC61S
Obviously you'd have to find a tire you like that would look good with the lettering painted and perform and last the way you'd want it to, but it's just another thought.
Car: 88 SC, 89 Silvy, 13 Cruze
Engine: LO3, LO5, LUW
Transmission: 700R4, 700R4, M40-6
Axle/Gears: 2.73, 2.73, 3.94
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Just a chime in question, isn't the Indy 500 discontinued? I called a Firestone yesterday and they couldn't find it. Unless it's the 245/50/16 I was looking for. It's not the Wide Ovals either.
Car: '85 Z28
The Indy 500s only come is 225/60 for 16in tires. the Wide Ovals and Indy 500s are completely different
You need to look again, they come in 245-50-16 but black only
Car: 82,83,99 T/As
Engine: 350,350,383
Can you post a link to buy one? I need one in that size and black only, but can't find it anywhere. Even in that link, it doen't show the size even though it exists.
I have one, just need one more.
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
i know tirerack.com has them...
I don't know of any 50 series tire that's available with white letters... there's just not enough real estate to make that work
Car: 82,83,99 T/As
Engine: 350,350,383
No no, I meant TireRack has 15s in Indy 500s. They don't have 16s which are blackwall. I'm looking for the blackwalls.
i'm sorry I'm just confused...
you're looking for 245/50/16? in blackwall?
correct?
correct?
Car: 82,83,99 T/As
Engine: 350,350,383
Yup. Firehawk Indy 500 (Non wide ovals). The local firestone said they're discontinued.
I pulled that info from Firestone's website. Put your year, model, sub-model...then choose!
Car: 82,83,99 T/As
Engine: 350,350,383
No show. Only Indy500 Wide Oval and WideOval. I'll stay on the hunt.
Engine: gone
Transmission: gone
Axle/Gears: gone
did the OP pick a dang tire yet? haha
yeah, when I buy tires, I'm pretty sure I'm going to go with the T/A's...
one more photoshop.. this is fun!
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Firestone Indy 500
P235/60R15
P235/60R15
Car: 1992 Firebird convertible
Engine: 5.0 tbi
Axle/Gears: stock, slow and steady 2.73's
i got the indys, im on my second set of them, t/a look like a truck tire to me
yeah... as soon as the roundup is done I'm going to sand down my car and repaint it. I'm going to repaint my wheels probably at the same time, then after they are painted I'll put new tires on. I'm going back on forth on black or white. I think it's honestly going to depend on how dark the car is. If the color grey I get is lighter, I might go white letters. if it's darker, then it's blackwalls for me
If I do blackwalls, I may end up getting these tires... amazing stats and they look great too
http://www.tirerack.com/tires/tires....omCompare1=yes
I'd be curious to see what they'd look like in our 65 size though, hard to picture that tread pattern on such a tall and narrow tire as opposed to a low pro...they do look good though.
Definitely start a thread when you go to paint, and I think you should stick with the original color, but you know me
I am going to stick with the original color paint, But I am replacing what is on there with bc/cc
I'm also going to put heritage stripes on
Engine: gone
Transmission: gone
Axle/Gears: gone
I almost bought the hydroedge's. Then I really started reading reviews. Mostly on treaddepot.com.....Almost everyone that went to the toyo's I am running. Switched over from Michelins. They all said the toyo's ran quieter, smoother, lasted longer. Those Hydroedge tires (i talked to my alignment guy) he said they always wear in a feathering pattern.
interesting...thanks
Engine: gone
Transmission: gone
Axle/Gears: gone
Sorry. I dont know if you wanted input on them or not...
In case you are wondering I am running Toyo Versado's in 215/65/15
I am interested. I looked up to see if tire rack sells them, but they don't. I'll have to keep looking
Engine: gone
Transmission: gone
Axle/Gears: gone
I bought them. Treaddepot.com is where I got them
Car: 82,83,99 T/As
Engine: 350,350,383
They do. But non-RWL. If you try to search for it, seems like it never existed. I know for a fact they made it as I'm running one of those tires right now.
Car: 1992 RS
Transmission: Automatic
Pac J
May 17, 2020 10:44 AM
The T/As have always been my favorite tire, IMO the lettering on the indy 500s looks cheap and out of place.
