Wheel wear problem
Old Apr 19, 2011 | 09:42 PM
acsvendsen's Avatar
Car: 89 Camaro RS, Black exterior,
Engine: Stock 305 TBI, K&N air filter
Transmission: stock 700r4
Wheel wear problem
Hey guys I have a quick question that may or may not be able to be answered. My right front tire seems to be wearing much quicker than my left front tire. I had gotten my car aligned by I know the speed bumps at my college are extremely high so thought that may be a cause for needing another alignment? Or my brother said it might be a worn bearing in the right. Any ideas? anything is useful.
Thank you!
Alex
Oh and by the way its an 89 RS TBI 305. Does not have the racing suspension package and only discs in the front. Drums in the rear. 15 in stock rims. I run Fuzion HRI tires. They're H rated instead of just t or s
Old Apr 19, 2011 | 10:05 PM
acsvendsen's Avatar
Re: Wheel wear problem
I had recently put 2 new tires on. I got my front end aligned then put the 2 new tires on because of the front right wear. I switched the 2 in the rear to the front and put the new ones on the front.
Hope some of this info helps.
Old Apr 20, 2011 | 09:50 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
bad front strut maybe?
Old Apr 21, 2011 | 09:10 PM
acsvendsen's Avatar
how would you even check that though?
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
z28_AJ
Aug 27, 2015 08:59 PM
Fronzizzle
Aug 9, 2015 01:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
