need help with spacer size
Old Mar 1, 2011 | 09:16 PM
raith's Avatar
Car: 92 Camaro RS, 84 Recaro T/A
Engine: LS2, none in the TA at the moment
Transmission: T56, 700r4
Axle/Gears: 3.23 posi, G80 LSD
looking at getting these rims for my 92 RS http://www.tirerack.com/wheels/Wheel...All&sort=Brand
specs are below
Front:
Offset: 56mm
Backspacing: 6.92"
Bolt Pattern: 5-475
Rec. Tire Size: 245/40-18
Weight: 24.6lbs. each
Rear
Offset: 56mm
Backspacing: 7.44"
Bolt Pattern: 5-475
Rec. Tire Size: 275/35-18
Weight: 26.4lbs. each
what i need to know is what size spacers i'm gonna need to get these to fit properly. my Camaro is at stock height, and mostlikely will stay that way. (maybe a 1" drop in the future, depending on how these rims fit)
Nervous2
Oct 8, 2015 10:53 PM
the_hamturdler
Exterior Parts for Sale
Sep 21, 2015 08:55 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
m00n420
Sep 11, 2015 02:39 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
