Can I still use these?
Car: 85 Firebird & Grand Prix GXP
Engine: LG4 305 (originally 2.8L V6)
Axle/Gears: 10 bolt 3:43 Open Diff.
I'm supposed to be picking up a couple BFG Drag Radials in the morning. They have no visible tread left and I was wondering if they should still be ok to drive on?
Keep in mind my car is still in the early project stages even (after a few years) and I only drive it about 100 miles a year in the summer. I just wanted a wider looking tire in the rear for looks.
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Re: Can I still use these?
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Sure they might get you from A-B if its a short distance but they will have no wet weather traction, you can not burn them up and get them sticky, because they may blow. The geometry of the tire may become deformed if you ride on them more than a few times. They can bubble, split, tear, separate you never know.
IMO its not a good idea, scrap them they are no good for the purpose they where made for anyway. Save up for a new set or search for a better used set. People are constantly upgrading to new track tires, I'm sure you can find something better than a completely worn out drag radial.
PS. I hope you are not paying for these.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if they are bald, they are bald, you can use them to mockup, or push the car around the driveway/garage, but i wouldnt drive on them.
Alright, thanks guys. I just called the guy and told him I'm not taking them. They were cheap and came with a couple Camaro rims I was going to sell so basically I'd break even, that's why I was considering it.
Car: 1985 IROC-Z
Engine: 355
What kind of Camaro wheels? If they are a set of early Irocs that you can make nice of, you may be able to make a few dollars.
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah i wouldnt run them but the rims may be worth it for the right price
They're the "salad shooter" style. I told the guy I wasn't taking them already unfortunatly.
