10" wide wheels front and rear, any issues?
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Re: 10" wide wheels front and rear, any issues?
Im running into the same issue with my new wheel/tire set-up. I'm getting 11's for the rear so I'm looking at a 305/35/18 which is a 26.4" tire..I was originally looking at a 315/30/18 which is only 25.4...too small in my opinion.....you could go that route an avoid the harsher ride the 19's will give you....and avoid the crazy upcharge on 19's...lol
Car: 87' IROC
Car: '91 TA vert
Engine: turboLSx
FWIW, I've ran a 27.1" tire on my rear 19s since I got them. It's amazing how much better it fills out the fenderwells.
Do you have a forward and/or backward shot to show how the +44 sit in the fenders? (how close are they to the lip?)
Car: 87' IROC
Car: '91 TA vert
Engine: turboLSx
I do, not quite as large because I unfortunately run a staggered setup (18/19). 26.7"
Car: 1992 Camaro RS
Engine: 5.0 TBI L03 V8
Transmission: Rebuilt 700R4 W/ Corvette shift kit
Axle/Gears: 2:73 open
I just slapped on some 285/40-17 in the rear of mine. It looks fantastic, bit if I could fit some 305s I would.
Car: 87' IROC
Car: '91 TA vert
Engine: turboLSx
The only rubbing I have is full lock to the right in reverse. Rubs the backside of the fenderwell/firewall junction. However, the wheel is tucked inside the fender a 1/4" or so. If it was even with the fender like the rear is I'd probably have a bit more rubbing? What kind of offset/wheel position are you looking for?
Car: 87' IROC
Car: 87' IROC
Ugh, I hate how tire availability is driving what size wheels I get rather than what will fit.
The R-S3's are sold out for the foreseeable future.
Now it looks like I will go with Bridgestone RE-11's. Good tire, but more expensive.
Front
265/35/18 on 9" wheels
Rear
285/35/19 on 10" wheels
The other option is just to run the 285/35/19's on all corners on 9.5" wheels. But I am still concerned that that tall of a tire will give me problems on the front.
Front
Rear
Car: 87' IROC
Well I finally got a firm order in for wheels.
Ended up with HRE 560r's.
And I ended up with 19x10's all around with 285/35/19 Bridgestone RE-11 tires.
Lesson learned, the longer you look, the more expensive your tastes get.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Those are going to look nice! What offsets and finish did you end up getting?
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
19's will be harsh on the ride no? I would probably go for 18x9.5 just for the sake of ease of fitment and my needs (more street than track) and run 275/35/18 tires. This would work well with what I have now, although not sure how well that would work with racecraft 2" dropped spindles which I am planning on installing.
What backspacing would be required to run this wheel size on our cars? And is there any company that makes IROC replica's in custom sizes such as 18x9.5? I just love the stock IROC wheels more than any other wheel but they lack the size of modern performance handling cars..
(Not wanting to hijack the thread, but it sort of pertains to what the OP wanted to install originally)
Car: 87' IROC
Finish will be a brushed center and polished lip. Finish should look something like the wheel on the left:
Car: 87' IROC
I personally think an 18x9.5" will not fit with the drop spindles. I'm not sure even 19's would work. If I ran 9.5"s on my car I would use about a 6" backspace if you have aftermarket brakes and 5.5" BS with stock brakes.
Nobody I am aware of makes 18x9.5" IROCs, and I did look. What you can do is have them widened or narrowed to any width you want. I thought about this, but at the end of the day you have still spent a lot of money and only have Chinese cast wheels. Not something I really wanted to risk on my rig.
True that regular 18's would be the limit so I guess you should be fine with that size.
To have the wheels fit with drop spindles, I would need less backspacing probably so that the wheels stick out more? I do have aftermarket LS1 brakes in the front but not the rear.. Quick question, do the LS1 rear brakes make the rear wheels stick out 0.3" just like it does in the front?
Car: 87' IROC
The LS1 rear brakes should not meaningfully change the rear track since even the OEM brakes had slip on rotors, unlike the stock fronts.
Right now I have aluminum drum brakes in the rear. If I put LS1 brakes back there, would 5.0" BS be right for both the front and rear wheels (with 2" dropped spindles in the front) and would the wheels bolt up fine (ex: enough thread engagement). Thanks!
Car: 87' IROC
Then how wide do you want on the back? If you are planning on 9.5" wheels, I would do about a 5.5-6" BS. That will put the face of the rim just tucked into the fenders. Its all about what you like though.
Can you explain why you insist on the drop spindles? While they are a good idea, I'm not sure they are worth losing that much tire.
Regarding the wheel studs. Even stock studs on stock rims are really shallow. At least mine were on my 9 bolt. I would upgrade to longer studs regardless.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
ooh those are purdy!
and oddly enough, they look like my new wheels, just with a dish
I like the hidden hardware too
Car: 87' IROC
Car: 87' IROC
Engine: LB9, LB9
8 month's? You posted on 2/12/12 that you finally got a firm order in on the wheels. Can't wait to see them mounted though.
Car: 87' IROC
So yes, I have been trying for 8 months. Nobody wanted my money except for HRE.
Car: 86 Trans Am
i'll take money if you giving it out
I do love those wheels. The more i see them the more drool i need to clean from my desk.
what are you doing for a front center cap? anything? i dont see them working well, mine dont.... but i planned ahead for that
Car: 87' IROC
All the pictures are of the rear wheel. The front wheel has a much thicker back pad to accommodate the front spindle. The normal HRE center cap will fit. For instance both wheels are 6.375" BS but the front wheel has a 2" lip and the rear will be 3" lip. I will have to trim the excess threads off the spindle and run a custom dust cap.
Car: 87' IROC
Wheels have arrived. I have two tires coming tomorrow or Wednesday. I am going to slap two 285/35/19"s on the front wheels and make sure they actually fit in the wheel well like I think. Worst case scenario they don't fit, 285's go the rear and 265's go up front.
Car: 86 Trans Am
is that gold lip?
more copper i guess...
Car: 87' IROC
Car: 87' IROC
I slapped the one wheel on. Obviously it looks kinda weird without a tire and at full suspension droop. Finally, the extra threads on the spindle will have to be trimmed off in order to fit the center caps. All part of the plan.
Car: '91 TA vert
Engine: turboLSx
Your attention to detail is now explained by the Pcar.
The wheels looks beautiful.
Car: 87' IROC
Car: 86 Trans Am
you need bigger brakes now for sure, lol
looking good, should be pretty sweet once its back together.
Car: 87' IROC
Car: 86 Trans Am
what are you using for tires? brand/style not size
Car: 87' IROC
Car: 1985 IROC-Z
Great looking wheel!
I had to grind down the wheel axle in the front too to fit my center caps. Still need to make a dust cap for it though.
Car: 87' IROC
I got two tires mounted. Fits pretty well in the front. I will have to adjust the a-arms slightly so the wheel sits a little closer to the front of the wheel well.
Car: 87' IROC
I wanted to take a few minutes to share my excellent experience with HRE Wheels.
Yes, HRE Wheels are expensive, but after how they treated me in a tough situation, the price is totally worth it. I know I will get taken care of for life.
To summarize, I have been in the market for wheels since last July. I originally placed an order with Boyd for a set of PT-01's. After working with them and my dealer for several months, Boyd went out of business. The Boyd's were already at the higher end of my budget. But the longer these things take, the higher the budget gets, I'm sure you are familiar with that sensation. My next try was with ISS Forged for a set of FM-8 wheels. I worked with ISS for many months trying to get the fitment nailed down. I am an engineer by trade and I know what I want. ISS seemed to lack technical skills and I could never get a straight answer on measurements. I finally had to let them go. At this point I started looking even higher budget, D2 Forged, etc.. They were not willing to do any fitment or engineering on the wheels until they had a 50% deposit. That was not going to fly with me. At this point I felt doomed to never order custom wheels.
Then I found the HRE 560R design at a somewhat more affordable cost than their other lines. These were still way over budget but I figured I would at least initiate contact and see where things went. So I called and talked to Tito. Wow, what a difference from all the other companies I have dealt with. Tito was knowledgeable, fast, and willing to work a fitment before an order was placed. Tito and I worked a great fitment for a few weeks, this was around the Christmas holiday. HRE's fitment paper work package is a huge advantage over the competition. They have you take a bunch of measurements of your wheel wells, brakes, etc.. The other companies I dealt with were not organized in any way. HRE always responds to my emails very quickly and always has the information I need. I finally got my order in for the 560R's. During the build process, HRE provided me with pictures of the wheels at various stages of production. I really appreciate the pictures, they tell a story.
Long story short my wheel dealer, PTS, became unresponsive after the order was placed. I had paid PTS the full amount for wheels and tires up front. PTS told me they had paid HRE 100% up front. I later found out they only gave you guys a deposit. When the wheels were ready to ship, Perry did not pay the remaining balance. I initiated disputes with PayPal and my credit card company. Initially PayPal was unable to recover the funds and it looked like I wasn't getting my money back. HRE made sure to keep me calm and told me we would work out something. As it turns out HRE was willing to ship the wheels even with just the initial deposit from PTS. I thought that was shocking. I have purchased tons of aftermarket parts from tons of companies and never received customer service like this. The day after the wheels shipped, I was able to recover much of the money paid to PTS. I contacted HRE to ask them how I could pay them the remainder of the money owed from PTS.
In short HRE told me we were good and no additional payment was necessary. And he apologized for how painful the process has been. For HRE to treat me this way is absolutely stunning. I am sure the experience was painful for them as well. HRE took responsibility for their dealer network. That is above and beyond any expectations I would ever have. And to think I am just a guy with an old Camaro buying one set of their cheapest wheels. I am sure Tito and HRE engineers had many hours working the fitment. This was not an off the shelf build.
It is challenging for me to describe how impressed I am with HRE's customer service. They have been without a doubt the best company I have ever worked with, regardless of industry. Many of my friends, family, and co-workers and lots of thirdgen members have been involved in my car progress and have shared in my 8 month quest for wheels. They have all seen the way the HRE team treated me. I am not sure how many of them will ever be in the market for forged wheels, but many have told me they will come to HRE first based solely on my experience. I will as well.
So in short I can highly recommend HRE if you guys are ever in the market for forged wheels. I know they will take care of you. I worked with Tito and can highly recommend him as well.
TitoR@hrewheels.com
TitoR@hrewheels.com
Sounds like HRE has my business, or atleast a first chance at it when I decide to get custom wheels. Good to know there are businesses out there that are still human.
P.S. Your wheels are frickin awesome
Car: 1985 IROC-Z
That's good to hear about HRE. I just went through a custom forged 3 piece wheel order and did not have nearly as good of purchasing experience. It's a shame when you plunk down $1K per wheel and you have to pull teeth to get info when you want it.
Car: 87' IROC
Yup. That was my experience with other companies as well. I think most of the 3pc wheel companies are just design houses and outsource construction to other companies. Therefore they are short on engineering. I know HRE builds a lot of private label wheels for other companies.
COTM Editor
87350IROC - your car is gonna look amazing on the ground! Can't wait to see how this all unfolds
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
I've heard nothing but good things about HRE and wow do they look good. I went the lower end of the 3 piece wheel and got CCWs which i had A+ service with. Good to hear there are companies out there that take care of the buyer.
Car: 87' IROC
The CCW's are awesome. I would have gotten a set of classics or LM5's if they were available in 19's.
