Wheel question
Old Jul 16, 2011 | 12:24 PM
91RealSlow's Avatar
Car: 1991 camaro RS
Axle/Gears: Stock 273?
Wheel question
I want to put 17s on my camaro but I don't know how wide to go in the front or real the car is stock height. I also don't know what type of tire I want. I just want something fun that I can corner with an maybe "drift" with. I was thinking 9" in the rear maybe 10" an 8" in front? And I really don't want to run spacers at all. Any suggestions ?
Old Jul 16, 2011 | 06:23 PM
Guest
Guest
Posts: n/a
Re: Wheel question
For drifting, you want wide wheels and not-so-wide tires. How about 17x9" all around, zero offset, on a set of 245/45R17 tires?
Also, for drifting, you want steel wheels. If your rear wheels smack a curb mid-drift, the steel will bend, not break like aluminum.
Cragar has at least 3 different styles of steel 17x9, with the bolt circle and offset you need, all under $100 each.
Pick a hard compound tire for the rear, with a treadwear number over 400.
Old Aug 8, 2011 | 06:57 PM
91RealSlow's Avatar
Car: 1991 camaro RS
Re: Wheel question
Example of a good cheap tire with a tread count over 400? I couldent find much on tire rack
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
