92-96 wheels on an 89 Rs?
Car: 1989 Camaro RS 5.0 TBI
I found a nice, set of these, they are about an hour and a half drive away.
Does anyone have pictures of these on the 3rd gen? or any opinbion son what theyd look like :P
Thanks!
Thanks!
Re: 92-96 wheels on an 89 Rs?
Will either of these work haha
#1 http://seattle.craigslist.org/sno/pts/2535299892.html
#2 http://seattle.craigslist.org/sno/pts/2536691486.html
I might crap my pants if #2 would fit
alright, thanks. I did a bit of googling and am figuring it out for the most part. I am considering some 05 corvette wheels or possibly 75vette rally wheels if the footprint works out no problem. Any clue if they do?
I am checking these out
http://seattle.craigslist.org/see/pts/2531819221.html
http://seattle.craigslist.org/tac/pts/2533312080.html
(hard to see in pic, but he says they are 9 of 10
The OEM Corvette ones might be a little wide in the back, not 100% sure. Also, they are like 19s in the rear and 18s in the front... or 20s in the rear and 19s in the front, which is REALLY big on a Thirdgen. 18s are about as big as you want to go.
The first set might bolt on, depending on the backspacing/offset, which he doesn't list.
Okay I think i found the wheels I want, but I need a second opinion as to if they will work.
http://seattle.craigslist.org/oly/pts/2546371252.html
Thanks!
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Thanks!
Thanks!
But if your set on Vette wheels, look around on TGO & you'll see that a lot of people who had them are selling them off & getting wheels that fit right the first time. IMHO, that tells me something when I see people selling off those things & switching to wheels they fit correctly. My motto is Do It Once & Do It Right.
With the right adapters, they'll fit. By the time you buy the wheels & adapters, just take that $ & buy wheels that fit right the first time without need extra parts (the adapters) or doubling the # of lug nuts from 20 to 40.
Thanks for your wise words, I will take your advice. I saw 200 dollars and thought it was a steal, but if I will have to mess around with adapters and extra lugs and such, it doesnt really sound worth it.
Guest
Posts: n/a
These should be 15x8 with 4" BS, which would be a -12.7mm offset. You can run these on all 4 corners, if you're careful with your tire sizes, and you roll your fender lips up front. You might fit up to a 255/60R15 in the rear, but good luck with more than a 235/60R15 up front.
drptop70ss
Oct 4, 2015 09:44 PM
punkmaster98
Sep 8, 2015 09:45 PM
